read the duty cycle value?
Posted: 06 Dec 2022, 08:53
by chromo23
Good morning,
the duty cycle value used in the pwm command must be stored somewhere.
Is there a command to retrieve it?
Re: read the duty cycle value?
Posted: 06 Dec 2022, 10:01
Doesn't it show at the pin state buffer page?
Not sure if that page is also/already available as JSON.
Posted: 06 Dec 2022, 10:13
by chromo23
And is retrieving the value from there for further processing (sending it somewhere / rules) possible somehow?
it isn’t ...
Posted: 06 Dec 2022, 10:16
Not right now.
But I guess it would make sense to make it available, like the pinstate is.
For example:
See:
https://espeasy.readthedocs.io/en/lates ... ing-events
Then scroll up a bit...
Posted: 26 Dec 2022, 17:02
by judie07
Have you made any progress? ->
viewtopic.php?p=61989#p61989
Posted: 26 Dec 2022, 23:28
by Ath
I have created Pull request
#4435 to enable the last set duty-cycle value to be retrieved for (internal) GPIO pins set to PWM or SERVO.
