I'm trying to do a simple rule to do something when MQTT import is updated, but it doesn't work ...
I've tried with : ( My taskValueSet works fine if I put it on the tools command line )
on Linky#power do
TaskValueSet,5,1,2
Or
on Linky#Conso_VA do
TaskValueSet,5,1,2
without success
I can see this in the log file : IMPT : [Linky#Conso_VA] : 1070.00
Thanks for your help
MQTT import rule trigger
Re: MQTT import rule trigger
Your second event, on linky#conso_va do, should work once you enable the 'Generate events for accepted topics' checkbox, assuming your MQTT topic is 'power'.
Great, it works
Thank you very much !
Users browsing this forum: Ahrefs [Bot] and 29 guests
