Mqtt adafruit.io
Posted: 22 Nov 2022, 13:29
by Simba
In adafriit.io i have a toogle button and when i active it i receive this in log:
Command: feeds
1341366564: Command unknown: feeds,2357554,1
Or
Command: feeds
1341366564: Command unknown: feeds,2357554,0
how can i make a rule to change gpio?
Example that doesn't work
On feeds do
If %eventvalue1%=2357554
gpio,2,%eventvalue2%
Endif
Binary Filename: ESP_Easy_mega_20220809_collection_B_ESP8266_4M1M
ESP Board Name: Espressif Generic 1 ESPEasy 4M Flash 1M FS
Thanks you for help
Re: Mqtt adafruit.io
Posted: 22 Nov 2022, 13:47
Can you define the text to be sent by adafruit.io?
If so, please try to change it to "event,feeds"
Posted: 22 Nov 2022, 19:18
by Simba
Thank you for your reply.
I looked but I did not find how to change the sending of the adafruit
Posted: 22 Nov 2022, 21:52
Can you setup the topic to which you want to send messages?
Posted: 23 Nov 2022, 19:59
by Simba
Posted: 23 Nov 2022, 20:07
by Ath
What have you configured to reach the ESP from Adafruit.io, at some point you must have configured the URL, or a MQTT Controller?
Posted: 23 Nov 2022, 20:27
The reasoning behind my question for MQTT topics is that you can also use some of the MQTT topic as part of the command structure.
See the documentation:
https://espeasy.readthedocs.io/en/lates ... #c005-page
Posted: 24 Nov 2022, 12:48
by Simba
configuration of my openhab mqtt:
Controller Subscribe: Username/feeds/#
Controller Publish: Username/feeds/%sysname%_%valname%
On adafruit i do not configure anythink
I changed Controller Subscribe with Username/feeds/cmd/#
But I lost the connection with adafruit and at the moment I can't find it
Posted: 25 Nov 2022, 09:49
by Simba
@TD-er,
Thanks you for your help.
I resolved the problème with the plugin Mqtt Import
Have a good day.
Posted: 25 Nov 2022, 10:34
Great!
Good to know you got it worked out.
Have fun with it and also a good day to you too.
