Using MAX6675 with K-type thermocouple, on the Devices page the Interval is set to 1 sec, but the output is quite noisy.
Is it possible to set an interval below 1 sec then do some averaging in the Rules?
Tony
MAX6675 Interval
Re: MAX6675 Interval
Not sure about the minimal sample interval of the sensor itself.
But it is possible via rules to sample at a shorter interval.
You an use the msec version of looptimer.
When handling this looptimer, you can call "taskrun" on that task. (This will also flush data to a connected controller)
In the latest (not with LIMIT_BUILD_SIZE defined) builds you can check to use the pluginstats.
See:
- https://espeasy.readthedocs.io/en/lates ... tats#stats
- https://espeasy.readthedocs.io/en/lates ... statistics
This does allow you to simply get the average over the last N samples.
Also the peaks are logged, but those have to be reset by the user if you need to see the peaks since the last call to reset.
See:
Thank you - really helpful
