tele/Zaehler/SENSOR = {"Time":"2022-11-14T15:24:00","SML":{"Verbrauch":1.474,"Einspeisung":0.770,"Watt":26.000}}
pi@raspberrypi:~ $ man woman
No manual entry for woman
pi@raspberrypi:~ $
pi@raspberrypi:~ $
# python 3.8.10
import random
import json
from paho.mqtt import client as mqtt_client
broker = '192.168.xxx.yyy'
port = 1883
topic = "Zaehler/SENSOR"
client_id = f'python-mqtt-{random.randint(0, 100)}'
def connect_mqtt() -> mqtt_client:
def on_connect(client, userdata, flags, rc):
if rc == 0:
print("Connected to MQTT Broker!")
else:
print("Failed to connect, return code %d\n", rc)
client = mqtt_client.Client(client_id)
client.on_connect = on_connect
client.connect(broker, port)
return client
def subscribe(client: mqtt_client):
def on_message(client, userdata, msg):
data=json.loads(msg.payload)
result = client.publish('Zaehler/SENSOR/Watt',data['SML']['Watt'])
status = result[0]
client.subscribe(topic)
client.on_message = on_message
def run():
client = connect_mqtt()
subscribe(client)
client.loop_forever()
if __name__ == '__main__':
run()
pi@raspberrypi:~ $
pi@raspberrypi:~ $
What do you think ...
