Sonoff POW R3
I tried the latest espeasy builds (example ESP_Easy_mega_20220616_hard_SONOFF_POW_4M1M)
setting
Energy (AC) - CSE7766 (POW r2) [TESTING]
Energy (AC) - HLW8012 / BL0937 [TESTING]
but I have no value
Maybe the POW R3 is not supported?
support Sonoff POW R3
Re: support Sonoff POW R3
According to this site: https://templates.blakadder.com/sonoff_POWR3.html
It uses the same chip as the POW R2: https://templates.blakadder.com/sonoff_Pow_R2.html
in fact, with Tasmota it works regularly
.... I wanted the same with Espeasy
You must probably turn off the Serial port on the Tools/Advanced page, as the CSE7766 uses the common serial gpio pins. Keeping the serial log enabled will interfere with the proper working of the sensor.
i deactivated the serial port ... but it doesn't work anyway
Browsing through older issues, I found this: https://github.com/letscontrolit/ESPEasy/issues/3991
Or actually, Ton found it...
See this older forum thread: viewtopic.php?p=58219#p58219
works with
ESP_Easy_mega_20200801_hard_SONOFF_POW_4M1M.bin
a question: what is the value " Pulses"
thank you
thank you
