Hello, How can I unblock or activate the plugin from the \ ESPEasy_ESP82xx_mega-20220809 \ source \ src folder
I mean the _P072_HDC1080.ino plugin which cannot be seen in devices / device on the configuration page on wemos d1mini ??
How to enable plugin?
Re: How to enable plugin?
In the list of official plugins, here you can see that it's included in the Collection A and Climate builds. As Climate builds have only been introduced after the last release, you should install the Collection A build on your Wemos d1 mini (updating via the Update Firmware button on the Tools page should work), when that's completed you can select the plugin.
it worked, thank you for your help.
