Calculate: Unknown token input: 40 do = 0
EDsteve
#1 Post by EDsteve » 05 Oct 2022, 11:40
Hi there,
I am not sure why this simple rule does not work any more. I have used it a few years ago. But when i try using it on the new built. It gives me the error:
Here my (simplified) rules which are based on the wiki:
on BME_280#Temperature do
 if [soil#Analog]>40 do
   timerSet,1,2
I found several posts with similar problems but couldn't really get a solution from it.
Would be nice if someone can point me into the right direction.
Cheeers
ED
chromo23
Re: Calculate: Unknown token input: 40 do = 0
#2 Post by chromo23 » 05 Oct 2022, 12:01
 if [soil#Analog]>40
   timerSet,1,2
That should do the trick ;)
Edit: to be clear .. the do is only needed for the primary "rule block" like
On BME_280#Temperature Do
 //something is happening here
Additional infos can be found in the Rules part of the documentation:
https://espeasy.readthedocs.io/en/lates ... Rules.html
EDsteve
#3 Post by EDsteve » 05 Oct 2022, 12:06
Grrrrr. And i said it was based on the wiki. But yea. There is no "do" in the wiki in the if statement (any more?).
Thanks for the correction :)
Works as it should now.
#4 Post by TD-er » 05 Oct 2022, 12:25
Please refer to the ReadTheDocs and not the wiki.
The wiki is really really outdated.
Users browsing this forum: Bing [Bot], Google [Bot] and 89 guests
