This is about as close as it's got to actually booting.
There is more than enough power going to the module. I get pretty much the same no matter what binary I try to use. 2 modules are doing the exact same thing. I have a couple new ones on order. I have a dozen of these tho.....
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
ets_main.c 371
ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0030,len:184
load:0x40078000,len:12616
load:0x40080400,len:2916
entry 0x400805c4
▒U30 : Info :
INIT : Booting version: ESP_Easy_mega_20221003_normal_ESP32_4M316k_LittleFS, (GitHub Actions) mega_499f25c (ESP32 SDK v4.4.3-149-g10ab11e815)
32 : Info :./components/esp_littlefs/src/littlefs/lfs.c
error: Corrupted dir pair at {0x0, 0x1}
INIT : Free RAM:274200
33 : Info : INIT : Cold Boot - Restart Reason: CPU0: RTC Watch dog reset digital core and rtc module CPU1: for APP CPU, reseted by PRO./components/esp_littlefs/src/littlefs/lfs.c
CPU
34 : Info : FS : Mounting...
FS : Mount failed
42 : Error : FS : Mount failed
RESET: Resetting factory defaults... using default settings
RESET: Warm boot, reset count: 0
RESET: formatting...
RESET: formatting done...
6653 : Info : SaveToFile: free stack: 7416
8076 : Info : FILE : Saved config.dat offset: 8192 size: 820
8078 : Info : SaveToFile: free stack after: 7416
8079 : Info : SaveToFile: free stack: 7448
10113 : Info : FILE : Saved config.dat offset: 0 size: 3004
10115 : Info : SaveToFile: free stack after: 7448
10116 : Info : SaveToFile: free stack: 7256
10229 : Info : FILE : Saved security.dat offset: 0 size: 593
10230 : Info : SaveToFile: free stack after: 7256
10241 : Info : SaveToFile: free stack: 7000
10329 : Info : FILE : Saved security.dat offset: 1024 size: 6
10330 : Info : SaveToFile: free stack after: 7000
RESET: Successful, rebooting. (you might
Brownout detector was triggered
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
entry 0x400805c4
▒U32 : Info :
34 : Info : INIT : Free RAM:273968
35 : Info : INIT : Soft Reboot #1 Last Action before Reboot: Background Task Last systime: 0 - Restart Reason: CPU0: Software reset CPU CPU1: Software reset CPU
36 : Info : FS : Mounting...
70 : Info : FS : Mount successful, used 151552 bytes of 323584
147 : Info : CRC : SecuritySettings CRC ...OK
167 : Info : INIT : I2C
169 : Info : INIT : SPI not enabled
170 : Info : WiFi : Start network scan all channels
