Progress bar for display
Posted: 21 Jul 2022, 21:08
by ohaldi
Hello. I want to display a progress bar. In my case I use a 16x2 LCD.
I would like each character (star) to display a 10 second delay.
However, I would like my two buttons to remain active while the progress bar is displayed. Does anyone have an example?
it would be nice if the character was a block.
I based myself on the following idea.
on System#Boot do // activé lors de la mise sous tension
LCD,1,1,"Progress bar"
timerSet,1,5 //Set Timer 1
on Rules#Timer=1 do
LCD,1,1,*
timerSet,2,10 //Set Timer 2
on Rules#Timer=2 do
LCD,1,1,**
timerSet,3,10 //Set Timer 3
on Rules#Timer=3 do
LCD,1,1,***
timerSet,4,10 //Set Timer 4
on Rules#Timer=4 do
LCD,1,1,****
timerSet,1,10 //Back to Timer 1
Re: Progress bar for display
Posted: 21 Jul 2022, 21:46
by Ath
That can be done a bit simpler:
on System#Boot do
AsyncEvent,Progress
on Progress do
let 1,%eventvalue1|10% // Default n = 10
LoopTimerSet,1,10,%v1% // Repeat timer 1 every 10 sec. for n times
on Rules#Timer=1 do
LCD,1,1,{substring:0:%eventvalue2%:****************} // Use enough * to allow all n loops to be shown
End you can send command "AsyncEvent,Progress" (10 steps) or "AsyncEvent,Progress=6" (6 steps) from anywhere (rules, Tools page, via url) to start the progress bar with an optional count of 10 seconds
Posted: 22 Jul 2022, 11:32
by ohaldi
Many thanks for your help. The rules are new for me.
Can you please help me again how to start the progress bar using a GPIO input (PIR sensor) and know if the progress bar has reached 100%?
Posted: 22 Jul 2022, 11:45
by Ath
ohaldi wrote: ↑22 Jul 2022, 11:32
Reacting on the PIR sensor is rather easy, I prefer to use a Switch task for that, and suggest to use the name PIR:
on PIR#state=1 do // Will be triggered when PIR detects something (most use an active-high output, change to 0 if PIR sensor has active-low output)
AsyncEvent,Progress // Using default
Responding to '100%' will require a definition of when 100% is reached, can you specify your expectations?
Posted: 23 Jul 2022, 08:05
by ohaldi
Once again, many thanks for your help.
My idea is to close a garage door automatically after a given time.
In fact, there will be two GPIO inputs. One to know if the door is already closed. Here the ESP does nothing.
Only show on the LCD that the door is closed. If the door is open, then the progress bar starts.
If a pir movement is detected on the second GPIO then the progress bar is reset.
If the progress bar reaches 100%, then on the GPIO (Relay) output, a pulse of approx. 0.5 seconds is made to start closing the door.
Posted: 23 Jul 2022, 11:27
by Ath
That is a clear description, thank you
For the Door sensor, you could add another Switch device, suggested name: Door, as a Switch allows to set a Debounce time, like 200 msec (not needed for the PIR sensor, that should provide a stable on or off signal).
The switch should probably pull the GPIO to GND when the door is open (and use an external pull-up of ~4k7 close to the ESP, because of expected wire length the internal pull up (80-100k) is too high and will cause false triggers)
To invert that door action, just set 'Inversed Logic' to checked on the Door device, and if your PIR sensor has active low, the same can be done there
Code could look like this (gathered from previous posts here)
on System#Boot do
AsyncEvent,PIR#State=[PIR#State] // Let the PIR eventhandler take care of the logic
on Progress do
LCD,1,1,"Timer started"
on Rules#Timer=1 do
if %eventvalue2%=%v1% // Have we reached 100%?
AsycEvent,CloseDoor
on PIR#state do // Will be triggered when PIR state changes
if [Door#State]=0 // Door open?
if %eventvalue1%=1 // (most pir use an active-high output, change the 'Inversed Logic' checkbox on the device for using low-active)
TimerSet,1,0 // Stop countdown
LCD,1,1,"Movemnt detected" // We only have 16 characters...
else // No movement, door close procedure can start
On Door#State=1 do // Door closed
TimerSet,1,0 // Stop any remaining timer loops, f.e. when door is closed manually
LCD,1,1,"Door is closed"
on CloseDoor do
LCD,1,1,"Door closing"
LongPulse_ms,14,1,500 // Pulse relay on GPIO 14 high(1) for 500 msec
NB: This is all air code, untested
Posted: 24 Jul 2022, 10:13
by ohaldi
Once again a big thank you for your idea. I will build a box with the components soon.
Posted: 29 Jul 2022, 15:40
by ohaldi
I made a quick test board.
Everything is on a good way. I am starting to understand how the rules work. It's really good but not evident.
I also used a Display with 4x20.
Your example works well. However if the door is opened and there is no PIR movement, the progress bar does not start and at the end of the 20 characters the relay do not send a pulse.
I will also add a button to slow down the progress bar from 10s per character to 60s. To have a longer delay (about 20min)
Best regards
Otto
The last codes:
// Project : Garage door management with an ESP8266
// Last Change : 29.07.2022 /Ho
// GPIO17 Door State
// GPIO02 Button lond Timer / 20min
// GPIO13 Relay Door closing pulse
// http://192.168.90.97/control?cmd=event,CloseDoor
on System#Boot do
on Progress do
// on DOOR#State=0 do
let 1,%eventvalue1|20% // Display with 20 characters
LCD,2,1,"Door is open"
LoopTimerSet,1,1,%v1% // Repeat timer 1 every 10 sec. for n times
on Rules#Timer=1 do
LCD,1,1,{substring:0:%eventvalue2%:********************} // Use enough * to allow all n loops to be shown
AsycEvent,CloseDoor
On DOOR#State=1 do // Door closed
lcdcmd,clear
LCD,2,1,"Door is closed"
on CloseDoor do
Pulse,13,1,500 // Pulse on GIPO 13 to close the Door
Posted: 29 Jul 2022, 16:13
by Ath
Ah, great, yes, I already expected that without PIR activation the close wouldn't happen, but wanted to wait your results first
Posted: 29 Jul 2022, 21:27
by ohaldi
I found the following solution without PIR activation.
on System#Boot do
on [Door#State]=0 do
TimerSet,2,0 // Stop timer 2
event,Progress
on Progress do
on Rules#Timer=1 do
lcdcmd,clear
timerset,2,10 // Timer to check it door closed after 10s
// AsycEvent,CloseDoor
On Rules#Timer=2 do // Door Timer
if [Door#State]=0 // Door still open?
LCD,1,1,"Repeat closing door"
TimerSet,2,10 // Repeat timer 2 until door closed
LCD,1,1,"Movement detected"
lcdcmd,clear
Posted: 29 Jul 2022, 21:36
by Ath
ohaldi wrote: ↑29 Jul 2022, 21:27
That needs the square braces removed or it won't work as intended
