relay on/off every minute
bledad
#1 Post by bledad » 19 Jul 2022, 18:50
hello,
i want use the relay on/off every minute and do not block the rules with wait
but no work
Let,1,0
Let,2,0
on Clock#Time=All,**:** do
//relais 1 pin 13 bassin
  if  %syssec_d% > 25200 and %syssec_d% < 79200 //de 7h a 22h
         if %v1% = 0
         Let,2,(%syssec_d%+60)// add 60s
         gpio,13,0
         Let,1,1
      if  %v2% = %syssec_d%  and %v1% = 1 // if v2 = second and v1 = 1
         Let,3,20
         gpio,13,1
         Let,3,30
         gpio,13,0
please can you help
thank
Re: relay on/off every minute
#2 Post by TD-er » 19 Jul 2022, 19:18
Do you mean something like this?
    gpiotoggle,13  // see: https://espeasy.readthedocs.io/en/latest/Plugin/P000_Relay.html?highlight=toggle#commands
    gpio,13,0  // Turn off
Another approach can be to use the looptimer, if you want another interval duration.
Then you enable the loop timer at 7 am and set the looptimer to 0 at 22h.
bledad
#3 Post by bledad » 19 Jul 2022, 19:29
thank you for toggle ,
but how to have a space of time on the toggle ?
gpio,13,0 > 1 minute > gpio,13,1 > 1 minute > gpio,13,0 > 1 minute > gpio,13,1 > 1 minute .......
between 7h , 22h
and no sleep, waiting ...
because i use other rules for other relays
chromo23
#4 Post by chromo23 » 19 Jul 2022, 19:36
deleted
the code TD-er wrote should do exactly what you asked for
bledad
#5 Post by bledad » 19 Jul 2022, 19:54
ok , I've found with Longpulse
         if %v1%=0
         LongPulse,13,0,60
         Let,1,1
         LongPulse,13,1,60
         Let,1,0
chromo23
#6 Post by chromo23 » 19 Jul 2022, 20:00
That´s another valid approach but the one TD-er suggested is much shorter and works the same way...
edit:
This is triggered every minute
That’s why the gpio is also toggled every minute with "GPIOToggle"
#7 Post by TD-er » 19 Jul 2022, 20:12
bledad wrote: 19 Jul 2022, 19:54 ok , I've found with Longpulse
         if %v1%=0
         LongPulse,13,0,60
         Let,1,1
         LongPulse,13,1,60
         Let,1,0
This will not work as you might expect.
Problem is that the longpulse will schedule itself to switch the state back after set interval.
But there might be some jitter between handling these scheduled actions of longpulse and event handling.
So after a while a new longpulse may be started right after the previous one has ended, resulting in very short interval flipping the GPIO pin.
bledad
#8 Post by bledad » 20 Jul 2022, 17:46
hi,
I was happy, but now less so , since I added another function
the gpio 14 does not stay at 900 s (15minutes)
how to do it
thank you
301903: WD : Uptime 5 ConnectFailures 0 FreeMem 18624 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
314347: EVENT: Clock#Time=Wed,17:40
314351: Cache rules event: rules1.txt pos: 67 on Clock#Time=All,**:** do
314376: ACT : LongPulse,14,0,900
314379: GPIO : port 14. Pulse set for 900000 ms
314381: ACT : Let,1,1
314397: ACT : gpio,12,0
314399: GPIO : port#12: set to 0
314410: ACT : gpio,13,0
314412: GPIO : port#13: set to 0
331902: WD : Uptime 6 ConnectFailures 0 FreeMem 18504 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
361902: WD : Uptime 6 ConnectFailures 0 FreeMem 18800 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
374347: EVENT: Clock#Time=Wed,17:41
374368: ACT : LongPulse,14,1,900
374371: GPIO : port 14. Pulse set for 900000 ms
374372: ACT : Let,1,0
374386: ACT : gpio,12,0
374388: GPIO : port#12: set to 0
374399: ACT : gpio,13,0
374401: GPIO : port#13: set to 0
391902: WD : Uptime 7 ConnectFailures 0 FreeMem 18968 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
421903: WD : Uptime 7 ConnectFailures 0 FreeMem 18968 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
434347: EVENT: Clock#Time=Wed,17:42
434365: ACT : LongPulse,14,0,900
434368: GPIO : port 14. Pulse set for 900000 ms
434370: ACT : Let,1,1
434386: ACT : gpio,12,0
434388: GPIO : port#12: set to 0
434400: ACT : gpio,13,0
434401: GPIO : port#13: set to 0
451903: WD : Uptime 8 ConnectFailures 0 FreeMem 18992 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
481902: WD : Uptime 8 ConnectFailures 0 FreeMem 18992 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
494347: EVENT: Clock#Time=Wed,17:43
494368: ACT : LongPulse,14,1,900
494372: GPIO : port 14. Pulse set for 900000 ms
494374: ACT : Let,1,0
494388: ACT : gpio,12,0
494390: GPIO : port#12: set to 0
494402: ACT : gpio,13,0
494403: GPIO : port#13: set to 0
//relais 3 pin 14 bassin
         if %v1%=0
         LongPulse,14,0,900
         Let,1,1
         LongPulse,14,1,900
         Let,1,0
       gpio,14,1
//relais 2 pin 12 fontaine
   if  %syssec_d% > 39600 and %syssec_d% < 72000 //de 11h a 20h
     gpio,12,0
     gpio,12,1
//relais 1 pin 13 sonette
   if  %syssec_d% > 28800 and %syssec_d% < 72000 //de 7h a 20h
     gpio,13,0
     gpio,13,1
#9 Post by TD-er » 20 Jul 2022, 17:56
You reset the longpulse counter each time you call this function (which is every minute)
Why don't you use a timer instead of running on each minute timer event?
bledad
#10 Post by bledad » 20 Jul 2022, 18:04
i not understand
this ??
chromo23
#11 Post by chromo23 » 20 Jul 2022, 18:05
Use a loop timer as suggested.
On System#Boot Do
	LoopTimerSet,1,900
On Rules#Timer=1 Do
	If [Var#1]=1
		GPIOToggle,14
    	Else
    		GPIO,14,1
    	Endif
On Clock#Time=All,**:** Do
  	If  %syssec_d% > 25200 and %syssec_d% < 79200 //de 7h a 22h
        	Let,1,1
   	Else
        	Let,1,0
  	Endif
     gpio,12,0
     gpio,12,1
     gpio,13,0
     gpio,13,1
bledad
#12 Post by bledad » 20 Jul 2022, 18:10
ok ,thank you , i try , I don't know all the functions yet
chromo23
#13 Post by chromo23 » 20 Jul 2022, 18:14
The code is actually quite simple if you know the commands.
You should have a look here for a better understanding : https://espeasy.readthedocs.io/en/lates ... Rules.html
Edit: i forgot an endif in the code...just corrected it
#14 Post by TD-er » 20 Jul 2022, 21:11
bledad wrote: 20 Jul 2022, 18:04 i not understand
this ??
LOL :lol:
Yep, something like that, but then in software :)
