[rules] problems with timer, not working as expected
borre
#1 Post by borre » 20 Jun 2022, 14:10
I have a machine that give high or low output ([switch#state]) to my esp.
when the machine turns on, a fan must blow.
when the machine turns off the fan most blow for 5 more seconds en than turn off (if the machine is still off).
In the rules I have problems with the timer in the code below it does not turn the fan off after 5 seconds.
if I place "timerSet,1,5" with "GPIO,4,1"
it turns the fan off when the machine is done.
but I need a delay, fan needs to blow 5 sec longer after the machine is done.\
what am i doing wrong
on System#Boot do
	//fan off
	GPIO,4,1
on switch#state do
	if [switch#state]=1
		//fan on
		GPIO,4,0
		// set timer for fan on 5 sec.
		timerSet,1,5
On Rules#Timer=1 do
    if [switch#state]=0
		//fan off
        	GPIO,4,1
I am using this version of esp easy:
Build:⋄ 20104 - Mega
System Libraries:⋄ ESP82xx Core 2.6.0-dev stage, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support
Git Build:⋄ mega-20191003
chromo23
Re: [rules] problems with timer, not working as expected
#2 Post by chromo23 » 20 Jun 2022, 14:58
does your switch have an intervall set in the device setting?
otherwise it should work..
(a look at the log is also often helpful...)
borre
#3 Post by borre » 20 Jun 2022, 15:18
chromo23 wrote: 20 Jun 2022, 14:58 does your switch have an intervall set in the device setting?
yes it has a interval set to 60 seconds.
but we I set it to 0 and save it, it goes back to 60
chromo23
#4 Post by chromo23 » 20 Jun 2022, 15:22
this is not your switch in the screenshot. i´m just asking because if your switch would have set an intervall < 5 sek your rule would not work because your timer would be set every intervall new and it will never finish...
borre
#5 Post by borre » 20 Jun 2022, 15:32
chromo23 wrote: 20 Jun 2022, 15:22 this is not your switch in the screenshot. i´m just asking because if your switch would have set an intervall < 5 sek your rule would not work because your timer would be set every intervall new and it will never finish...
I am sorry, this is my switch
chromo23
#6 Post by chromo23 » 20 Jun 2022, 15:43
ok..so what does your log say when using the switch...
#7 Post by Ath » 20 Jun 2022, 15:48
Can you please attach screenshots to the post, see the Attachments tab when editing the post, because:
- External image services will stop sharing your image after some time (from hours to months)
- External image services contain a *lot* of advertising and other unwanted/undesirable references
#8 Post by Ath » 20 Jun 2022, 15:51
And, having a settings version of 20104, that implies you are running a very old release of ESPEasy (2 years + ?), please upgrade that first and retest, before we can properly support this. Get the latest from here https://github.com/letscontrolit/ESPEasy/releases
#9 Post by TD-er » 20 Jun 2022, 23:05
Build "mega-20191003" which does indeed look a bit dated.
On the other hand, if you're runnning on an 1MB unit, you may not be able to perform OTA updates on recent builds.
borre
#10 Post by borre » 21 Jun 2022, 13:56
yes I know its a older version, I got 7 of these devices running here and like to have them on the same software/fireware.
bit afraid of breaking stuff with updating.
also found the fault, there is indeed a interval on the status switch (5 sec)
but I kind of need this.
I have 5 laser machines, each machine has a esp device (CLIENTS) reading the on/off status.
a HOST esp reads get the values of the CLIENTS through through "ESPEasy P2P Networking"
on the CLIENT under devices add a amount of seconds under "interval"
I used 5 seconds, now the CLIENT updates the state of that device every 5 clients to the HOST (through "ESPEasy P2P Networking")
Now by the HOST under rules, I have this:
on MONA#state do
	if [MONA#state]=1
		gpio,14,1
		timerSet,5,10
		gpio,14,0
On Rules#Timer=5 do
		gpio,14,0
client 5 (MONA) shares here state, when she does that, and state =1
then I set gpio14 to 1, and set timer5 to 10 seconds.
if timer5 is finish after 10 seconds, then it puts gpio14 to 0
BUT if within those 10 seconds client MONA shares here state again and the state = 1 then gpio14 is set to 1 again and timer5 is reset to 10 seconds again.
ect, ect, ect
This is done because when the laser machine is turned of, the CLIENT esp is also turned off and cannot set the machine stat to the HOST.
If there was some command which the HOST can check if the a CLIENT is still ON and Connect I should not have to use a 5 sec interval.
if I remove the 5 sec interval on the STATE device, the timerset works as expected.
(added the screenshot to the attachment tab, was not aware of this tab)
borre
#11 Post by borre » 21 Jun 2022, 14:12
hmmm have created some kind of work around but do not know why this works :?
interval of the STATE is still set to 5 sec
on System#Boot do
	//fan off
    	GPIO,4,0
    	// set variable MachineState to 0
    	TaskValueSet 11,4,0
on switch#state do
	if [switch#state]=1
		//fan on
		GPIO,4,1
		// set variable MachineState to 1
          	  TaskValueSet 11,4,1
	   	 if [Dummy#MachineState] = 1
	        	// set timmer to shutdown fan after 5 sec.
	       	 	timerSet,1,5
			TaskValueSet 11,4,0
On Rules#Timer=1 do
       if [switch#state]=0
		// if the machine is still off, than put the fan out
       		gpio,4,0
if I use
timerSet,1,5
	TaskValueSet 11,4,0
instead of
	timerSet,1,5
	TaskValueSet 11,4,0
Why is this?
chromo23
#12 Post by chromo23 » 21 Jun 2022, 14:50
since the timer fires independent of
Dummy#MachineState
in the working example i assume that the condition
is never met....
edit: this is something the log will tell you..
borre
#13 Post by borre » 21 Jun 2022, 14:58
chromo23 wrote: 21 Jun 2022, 14:50 since the timer fires independent of
Dummy#MachineState
is never met....
I dont understand, in the working example
	       	 	timerSet,1,5
			TaskValueSet 11,4,0
looks to me that [Dummy#MachineState] must be "1" before timer 1 is set to 5 seconds.
I checked it, and in the working example the [Dummy#MachineState] set to 1
#14 Post by Ath » 21 Jun 2022, 16:32
Having both the timer and the Interval at 5 seconds is making it very hard to debug/test, please try with the Interval set to 7 seconds, so there is at least a chance they don't coincide.
chromo23
#15 Post by chromo23 » 21 Jun 2022, 17:40
sorry..missed the post #10 so probably what i wrote before is nonsense. i´ll have a look at it later....
chromo23
#16 Post by chromo23 » 22 Jun 2022, 09:26
borre wrote: 21 Jun 2022, 13:56 if I remove the 5 sec interval on the STATE device, the timerset works as expected. [/b]
why not putting the state of the switch in a dummy device, give it a 5sec interval and share it with the other devices....then you can remove the interval of the switch
#17 Post by TD-er » 22 Jun 2022, 09:37
I think this may be a cause for problems (not sure if it is "the" cause)
on switch#state do
	if [switch#state]=1
You're acting on the event of the switch state and then, when it is handled, you're checking the current state of that value.
What you should do, is check what the state was when the event was generated.
This state is present in the eventvalues.
on switch#state do
	if %eventvalue1%=1
borre
#18 Post by borre » 22 Jun 2022, 10:53
Ath wrote: 21 Jun 2022, 16:32 Having both the timer and the Interval at 5 seconds is making it very hard to debug/test, please try with the Interval set to 7 seconds, so there is at least a chance they don't coincide.
Tested it with different intervals and timerSet values
but the result stays the same.
Can anyone explain why timer 1 does NOT get triggered
and why timer 2 gets triggered
//switch has a interval of 5 seconds
on switch#state do
	if [switch#state]=1
        	if [Dummy#MachineState] = 0
            		//fan on
	    		GPIO,4,1
	    		// set MachineState to 1
            		TaskValueSet 11,4,1
		//this one does not get triggered
	    	timerSet,1,8
			// This timmer get triggered
			timerSet,2,8
			// set MachineState to 0
			TaskValueSet 11,4,0
#19 Post by TD-er » 22 Jun 2022, 10:55
On tools->Advanced, uncheck this parameter (if available in your build)
Optimize Rules Cache Event Order:
Which reminds me, I still need to disable this by default.
Oh and change this part:
on switch#state do
	if [switch#state]=1
to:
on switch#state do
	if %eventvalue1%=1
#20 Post by TD-er » 22 Jun 2022, 11:01
Not sure why timer#1 does not get triggered.
Maybe some other event does also set the timer to some value before it gets triggered? Or set to 0 to disable it?
Maybe a typo in your rules in the block to handle the timer?
To be sure, you can add some LogEntry commands to send some values to the log.
	    	timerSet,1,8
	    	LogEntry,"Calling: timerSet,1,8"
chromo23
#21 Post by chromo23 » 22 Jun 2022, 11:20
borre wrote: 22 Jun 2022, 10:53
[/code]
because every 5 second it gets retriggered by the switch intervall and so it never finishes?
the intervall of the switch needs to be at least 9secs if your timer1 is set to 8secs
this is your "run timerSet,2,8 only once" - switch by setting the machinestate back after it happend.. so timer 2 can finish without beeing retriggered
			timerSet,2,8
			TaskValueSet 11,4,0
borre
#22 Post by borre » 22 Jun 2022, 14:11
chromo23 wrote: 22 Jun 2022, 11:20
[/code]
			timerSet,2,8
			TaskValueSet 11,4,0
Ah oke, It TIMER 2 gets restarted over and over again.
Now I understand, a timer cannot be trigger twice and get 2 times the output, it wil only run the output once.
Because the second time you trigger it, it cancel the first trigger and triggers it again, am I right? ??
TD-er wrote: 22 Jun 2022, 11:01 Not sure why timer#1 does not get triggered.
	    	timerSet,1,8
Oooooh LogEntry is new for me, this make life a lot more easy, thanks!!!!!
chromo23
#23 Post by chromo23 » 22 Jun 2022, 14:39
borre wrote: 22 Jun 2022, 14:11 Ah oke, It TIMER 2 gets restarted over and over again.
correct....
but it is in your example timer1 that gests restarted over and over again and timer2 finishes successfully.
borre
#24 Post by borre » 23 Jun 2022, 09:30
chromo23 wrote: 22 Jun 2022, 14:39
correct....
Ah great, then now I understand.
One more question:
Is it possible to check if a 'ESPEasy P2P Networking' CLIENT is active/online?
maybe in a more recent version of esp easy?
chromo23
#25 Post by chromo23 » 23 Jun 2022, 11:40
A similar problem was discussed here: viewtopic.php?p=57854#p57854
you could basically send a "i am alive" message from one device to another with an given interval and write some code what to do if the other device doesn’t receive anymore...
chromo23
#26 Post by chromo23 » 23 Jun 2022, 12:08
note to developer:
i think commands like sendto or sendtohttp should return if they where successfull sending in a way that can be used in rules.....
#27 Post by TD-er » 23 Jun 2022, 12:23
chromo23 wrote: 23 Jun 2022, 12:08 note to developer:
Yep, something like an event containing the error
Users browsing this forum: No registered users and 113 guests
