Issue with VL53L0X
g0ebel
Issue with VL53L0X
#1 Post by g0ebel » 01 Jun 2022, 18:08
I try to connect a VL53L0X (time-of-flight) sensor to ESP Easy.
In my understanding this sensor should be included in the main release since version mega-20210503 ("[P110] Move P133 VL53L0X from PluginPlayground to main repository").
I expected to see this sensor when I add a new device, but no distance sensor is shown up here in the drop down menu.
Tested with
ESP_Easy_mega_20210414_normal_ESP8266_4M1M
ESP_Easy_mega_20210503_normal_ESP8266_4M1M
ESP_Easy_mega_20220427_normal_ESP8266_4M1M
I2C scan shows
What I'm doing wrong?
Many thanks for your help,
Frank
Screenshot 2022-06-01 182851.jpg (33.17 KiB) Viewed 3183 times
Re: Issue with VL53L0X
#2 Post by Ath » 01 Jun 2022, 19:41
That plugin is included in the TEST_B builds, an overview, and in what build(s) they are available can be found here: https://espeasy.readthedocs.io/en/lates ... lugin.html
g0ebel
#3 Post by g0ebel » 01 Jun 2022, 19:56
Thank you so much.
I will test and report.
Best, Frank
g0ebel
#4 Post by g0ebel » 02 Jun 2022, 10:34
Solved by using TEST_B bin. Many thanks.
Frank.
#5 Post by Ath » 02 Jun 2022, 10:52
Great it all worked out, thanks for reporting back ;)
