Sensor Values calculating
Sasch600xt
#1 Post by Sasch600xt » 17 May 2022, 13:46
Hello all :)
I connected my LPG fuel tank sensor to my ESP32 in my Car.
I had already done this in my house control system with my local water tank at home, but now I have to do all the calculations inside of the car ESP.
First I have two values from the sensor at my ADS1115 connected and working with the ESP32:
Empty tank = 11760
Full tank = 25452
All other levels are in between these two values.
So I need to convert this into 0% till 100%
And if a value is higher or lower as the max and min value, the ESP should still show(display) and send (controller) only 0% or 100%
So no -4% or 107% Level as long my fuel tank is not physical change the shape :)
And IF my fuel tank is changing the shape, i have other problems then my sensor values :)
and since my fuel tank is a lot more shaking as my local water tank at home I need to avarage the sensor value.
My idea would be:
- getting sensor data every 10 seconds and store 10 of it it inside of the ESP32.
- Deleting the highest and the lowest value.
- summery all 8 values and divide it by 8.
send value to controller every 100 seconds and repeat procedure.
Or a continues solution, if you have a better solution in mind ?
So first question would be : Doable ?
second question: How ? :)
Thank you for your help and have a great day ! :)
Sascha
Re: Sensor Values calculating
#2 Post by TD-er » 17 May 2022, 14:46
To constrain a computed value, see..... Constrain ;)
To map the input to 0...100 output, you can compute it like this:
Empty tank = 11760
Full tank = 25452
on MyAnalogSensor#val1 do
  let,1,(%eventvalue1% - 11760) / 136.92  // (25452-11760)/100
  let,1,{constrain:[var#1]:0:100}
Just assuming your task is called MyAnalogSensor with first value called val1.
This set of rules will store the last reading in variable 1 ([var#1])
You can do other computations like averaging in the rules too.
Sasch600xt
#3 Post by Sasch600xt » 17 May 2022, 15:21
great to point me to the constrain function :)
looks great :)
This is very useful when we work with raw sensor values.
In my house control system (about local water tank) i have the line:
$percent=(GetValueInteger(59082)-$empty)/($full-$empty)*100; // convert to percent (0-100%)
But at the end of the line I have "times 100" instead of "divided by 100" ?
But so far I can tell it is working.
Was it a typo of you, or did I miss a thing here ?
"You can do other computations like averaging in the rules too."
is there a function for that as well, or do I have to do it by hand ?
So how could I store 10 values without using 10 variables ?
or is there a way to store it as an array and just add next value to it ?
and how to delete lowest and highest value before i do the avarage ?
my value for "empty tank" was just a guessing, so we have about 500 kilometers time before i need the calculation working wich is about in a week :)
so thank you already for the great informations :)
#4 Post by TD-er » 17 May 2022, 15:41
I just wrote it while waiting for a compile to finish, so it might be possible I messed up.
But I don't think so, as I precomputed it so you can read it as if it were in braces.
(A) / (B) * C == (A) / ((B) / C)
At least I think so ;)
#5 Post by TD-er » 17 May 2022, 15:43
Oh and we don't (yet) have an averaging function.
However you could add the new value to the same variable and incrementing a next variable.
In the end, after some time or if count > N, you just divide both (make sure the count isn't 0) and reset the total and the count.
Sasch600xt
#6 Post by Sasch600xt » 23 May 2022, 21:24
Hello :)
right now i did try to set my rule like:
on LPGLevel#LPG do
  let,6,(%eventvalue1% - 952) / 244.83  // (25435-952)/100
  let,6,{constrain:[var#6]:0:100}
var#6 always shows "0" as result
But this:
on LPGLevel#LPG do
  let,6,%eventvalue1%
and this:
on LPGLevel#LPG do
  let,6,(%eventvalue1%)
works fine
But when i start to calculate like:
on LPGLevel#LPG do
  let,6,%eventvalue1% - 952
or
on LPGLevel#LPG do
var#6 shows always "0"
So i could need a little help with syntax here :)
i use normal build at a 8266 latest 27.April.22
Thank you for your help :)
#7 Post by TD-er » 23 May 2022, 21:57
Adding an = might sometimes also help to let the rules parser know it needs to call the calculate function.
e.g. let,6,=%eventvalue1%-952
But first, let's make sure we know what the eventvalue is.
on LPGLevel#LPG do
  LogEntry,'Eventvalue: _%eventvalue1%_  Var6: [var#6]'
(added underscores to wrap the eventvalue, to see if there are spaces too)
By the way, do you have multiple entries for LPGLevel#LPG in your rules?
If so, then you might want to disable the reordering of rules blocks (Tools->Advanced page at the top)
One more idea... try to remove the spaces around the - sign in the let line.
Sasch600xt
#8 Post by Sasch600xt » 24 May 2022, 19:05
YAY :)
this is how it works perfect now !
on LPGLevel#LPG do
  let,6,(%eventvalue%-952)/244.83
so i removed all spaces in between :)
I bought you some coffee right now but i can´t afford a coffee always i make a mistake. Simply because i make too much mistakes lol :)
What do you think about a avarage function ? woulden´t that be cool ? :)
best result i had always with continius reading values and always deleting highest and lowest value of 10 entrys and then doing the avarage calculating. Because if you have bad sensors or too long cables there are always miss values like -250 degree in sommer at my pool or something like this :) if you have very bad sensors you might be deleting 2 highest and 2 lowest values. So maybe the function would be cool to set how many highest and lowest you want to delete. If you use good sensors in good conditions the answer could be "0" :)
But thank you again for solving my problems with the calculations syntax in rules :)
Have a great day !
Sascha :)
#9 Post by TD-er » 24 May 2022, 20:03
I am preparing to work on a function like that.
This in the form of some processing of ADC data.
Later this will be split into some object you can read from and write to in rules (and tasks)
Sasch600xt
#10 Post by Sasch600xt » 24 May 2022, 20:16
YAY :) Sounds great ^^
