Rules with several time/date ranges
marstu
#1 Post by marstu » 09 May 2022, 22:53
Dear all,
long time no see, because of being happy until a few days. since the last weekend I though about having the OLEDs of my ESPs only active for a few hours per day, with different time ranges at the weekend and during the week. I tried a lot, but didn't find a solution, I hope to get something running like the one below, but was not able:
on Clock#Time=All,**:** do
 LogEntry,"Processing One-Minute Clock Event: Time is %systm_hm%, Day=%sysweekday%"
 if %sysweekday%>=1 and %sysweekday%<=7
  if %sysweekday%>1 and %sysweekday%<7  // Allowed Date Range, Mon=2, Fri=6
   LogEntry,"Mon(2)-Fri(6) Detected, (Day=%sysweekday%)"
   if %systm_hm% > 18:00 and %systm_hm% < 21:00 // 6PM - 09:00PM Time Range
     LogEntry,"Oled Display Turn On Time"
     OledFramedCmd,display,on
   if %systm_hm% > 06:00 and %systm_hm% < 08:00 // 6AM - 8:00AM Time Range
  if %sysweekday%=1 or %sysweekday%=7  // Allowed Date Range, Sun=1, Sat=7
   LogEntry,"Sun(1) or Sat(7) Detected, (Day=%sysweekday%)"
   if %systm_hm% > 09:00 and %systm_hm% < 20:00 // 9AM - 8:00PM Time Range
  LogEntry,"Oled Display Turn Off Time"
  OledFramedCmd,display,off
Where is my mistake?
BTW: The idea was outside the ranges above the OLEDs should be off.
Thanks already for your ideas already and have a nice evening
marstu
ESP8266, ESPEasy (always latest mega release in use :D ), and Domoticz (only beta versions :) )
Re: Rules with several time/date ranges
#2 Post by TD-er » 09 May 2022, 23:12
Not looked through all the code, but this one looks weird:
With weekdays ranging 1...7, this check is always true.
marstu
#3 Post by marstu » 28 May 2022, 09:38
TD-er wrote: 09 May 2022, 23:12 Not looked through all the code, but this one looks weird:
Hi TD-er,
you are totally right, I changed the code slightly and now at least it is working from Mon to Fri, but not on Sat and Sun:
   if %systm_hm% > 18:00 and %systm_hm% < 22:00 // 6PM - 10:00PM Time Range
   elseif %systm_hm% > 06:00 and %systm_hm% < 08:00 // 6AM - 8:00AM Time Range
   elseif %sysweekday%=1 or %sysweekday%=7  // Allowed Date Range, Sun=1, Sat=7
I am not sure if there is an "endif" too much in between, but tried with one less with out a change. On Sat and Sun only a "display off" will be logged.
Any idea?
KR marstu
#4 Post by TD-er » 28 May 2022, 09:52
I just checked your rules in Notepad++ with the ESPEasy rules color highlighter and the ifs and elses to seem to match.
See: https://github.com/letscontrolit/ESPEas ... epad%2B%2B
Also your observation seems to match with the rules.
I just deleted the rest of the lines, so you can see for yourself:
// deleted
N.B. with the syntax highlighting, you can even fold blocks, which makes it easier to check for matching if... endif.
marstu
#5 Post by marstu » 28 May 2022, 13:27
TD-er wrote: 28 May 2022, 09:52 I just checked your rules in Notepad++ with the ESPEasy rules color highlighter and the ifs and elses to seem to match.
Great, thanks for the idea of using blocks, it should be better structured now, although
Anyway, the part for the weekend is not not working (see log entry below), although the time window fits and the day, but the display is still powered off. It should be on...grrrr
  • 334863879: EVENT: Clock#Time=Sat,13:15
    334863890: ACT : LogEntry,'Processing One-Minute Clock Event: Time is 13:15, Day=7'
    334863893: Processing One-Minute Clock Event: Time is 13:15, Day=7
    334863938: ACT : LogEntry,'Oled Display Turn Off Time'
    334863940: Oled Display Turn Off Time
    334863942: ACT : OledFramedCmd,display,off
I am really getting crazy, during the week it works well, but not at the weekend.
#6 Post by Ath » 28 May 2022, 14:18
The first IF in your event handler excludes sat (7) and sun (1), so trying to select either of them in the last ELSEIF in that block is never giving the desired result...
marstu
#7 Post by marstu » 28 May 2022, 18:36
Ath wrote: 28 May 2022, 14:18 The first IF in your event handler excludes sat (7) and sun (1), so trying to select either of them in the last ELSEIF in that block is never giving the desired result...
Thanks @Ath for the hint...grrrr...you are right:
  if %sysweekday%>1 and %sysweekday%<7  and %systm_hm% > 06:00 and %systm_hm% < 08:00 or %systm_hm% > 18:00 and %systm_hm% < 22:00// Allowed Date Range, Mon=2, Fri=6
  elseif %sysweekday%=1 or %sysweekday%=7 and %systm_hm% > 09:00 and %systm_hm% < 20:00// Allowed Date Range, Sun=1, Sat=7
I changed to the above, and at least now the display is on.
#8 Post by Ath » 28 May 2022, 19:07
marstu wrote: 28 May 2022, 18:36
Combining AND and OR without any round braces is probably not going to work as intended:
  if %sysweekday%>1 and %sysweekday%<7  and ((%systm_hm% > 06:00 and %systm_hm% < 08:00) or (%systm_hm% > 18:00 and %systm_hm% < 22:00)) // Allowed Date Range, Mon=2, Fri=6
This looked the most logical expectation.
NB: Untested, might need to be split up, for having too much logical operations in 1 line
#9 Post by TD-er » 28 May 2022, 19:24
You could also split it in 2 parts:
- Detect the day of the week and set the time thresholds accordingly
- Check the time against the set thresholds.
       let,1,6 // 6:00
       let,2,8 // 8:00
       let,3,18 // 18:00
       let,4,22 // 22:00
       let,1,9  // 9:00
       let,2,20 // 20:00
       // Duplicate the hours, as we only need 1 interval in the weekends.
       let,3,9  // 9:00
       let,4,20 // 20:00
  if %systm_hm% > [int#1]:00 and %systm_hm% < [int#2]:00
       // turn on
  elseif %systm_hm% > [int#3]:00 and %systm_hm% < [int#4]:00
       // turn on
       // turn off
marstu
#10 Post by marstu » 28 May 2022, 19:27
Ath wrote: 28 May 2022, 19:07
I changed to the following...
  if %sysweekday%>1 and %sysweekday%<7  and ((%systm_hm% > 06:00 and %systm_hm% < 08:00) or (%systm_hm% > 19:00 and %systm_hm% < 22:00))// Allowed Date Range, Mon=2, Fri=6
  elseif ((%sysweekday%=1 or %sysweekday%=7) and (%systm_hm% > 19:10 and %systm_hm% < 20:00)) // Allowed De Range, Sun=1, Sat=7
...but this message appeared in the log window:
  • 357003879: EVENT: Clock#Time=Sat,19:24
    357003889: ACT : LogEntry,'Processing One-Minute Clock Event: Time is 19:24, Day=7'
    357003892: Processing One-Minute Clock Event: Time is 19:24, Day=7
    357003904: Calculate: Unknown token input: ((19:24)) = 0
    357003906: Calculate: Unknown token input: (19:24) = 0
    357003923: Calculate: Unknown token input: (19:24) = 0
    357003933: ACT : LogEntry,'Oled Display Turn Off Time'
    357003936: Oled Display Turn Off Time
    357003938: ACT : OledFramedCmd,display,off
I have never seen such message highlighted before. So, obviously the "elseif" part is not working.
#11 Post by TD-er » 28 May 2022, 19:31
Better not make these if checks too complicated.
N.B. I did edit my post to remove the () in the if statement too.
marstu
#12 Post by marstu » 28 May 2022, 21:43
TD-er wrote: 28 May 2022, 19:31 Better not make these if checks too complicated.
Thank you very much, a much better and smart way to solve my problem. It works very well, and I definitively need to get more familiar with "let".
Kind regards and have a nice weekend
Users browsing this forum: Bing [Bot] and 12 guests
