Send HTTP request using Rules
MikeBZH44
#1 Post by MikeBZH44 » 24 Apr 2022, 16:04
I'm running ESP_Easy_mega_20220328_normal_ESP8266_4M1M on Wemos D1 mini
I'm reading a DS18B20 temperature sensor and I can see temperature change when I heat or cool the sensor.
But now I want to send HTTP request when the temperature is over or above a limit.
So I have enable Rules and I made this one :
on [TempECS#temperature] do
   if [TempECS#temperature]>30
      //Bascule sur OFF le module S1
      SendToHTTP <IPaddress>,8083,/core/api/jeeApi.php?apikey=<MyJeedomAPIKey>&type=cmd&id=1663
   if [TempECS#temperature]<25
      //Bascule sur ON le module S1
      SendToHTTP <IPaddress>,8083,/core/api/jeeApi.php?apikey=<MyJeedomAPIKey>&type=cmd&id=1664
The device for reading the DS18B20 is named TempECS and the value is named temperature :
But When I blow on the sensor to make the temperature rise above 30°, the HTTP request is not sent.
I also try whith a much more simple rule :
on [System#Wake] do
But nothing happen
Where is my mistake ?
Thank for your help.
Re: Send HTTP request using Rules
#2 Post by Ath » 24 Apr 2022, 16:20
In the event-name you should not use the square brackets, in variable replacement (any where else) you should, so changing to this:
on system#wake do
and
on TempECS#temperature do
will make it work.
MikeBZH44
#3 Post by MikeBZH44 » 24 Apr 2022, 17:34
Yes !! Thanks a lot !!!
#4 Post by TD-er » 24 Apr 2022, 20:39
Also during system#wake, you probably don't have a network connection yet.
So better to act on the WiFi#connected event.
MikeBZH44
#5 Post by MikeBZH44 » 24 Apr 2022, 20:59
that's right ;)
Users browsing this forum: No registered users and 105 guests
