HTTP Advanced Controller to Prometheus Pushgateway
Posted: 04 Apr 2022, 17:26
hopefully the post is in the right place here.
I tried to send an http request with the Generic HTTP Advanced Controller to a Prometheus Pushgateway but got an error because the controller plugin adds a "\r" at the end of the body line, also if its only one line.
The Prometheus Pushgateway on the other side has limitations:
"Note that in the text protocol, each line has to end with a line-feed character (aka 'LF' or '\n'). Ending a line in other ways, e.g. with 'CR' aka '\r', 'CRLF' aka '\r\n', or just the end of the packet, will result in a protocol error."
So my question is, is there a way to customize the body in some way to meet "only \n" requirement?
I did a custom build already, but I do not find the function I have to change or maybe someone was in the same situation and found a workaround?
Also I tried sending binary and sending without binary option checked... it does not make a difference.
I was building from "mega" branch yesterday.
Hopefully I provided all the necessary information ...
Information Pushgateway: https://github.com/prometheus/pushgatew ... /README.md
Many thanks in advance!
All the best,
Philipp
All the best,
Philipp
