hopefully the post is in the right place here.
I tried to send an http request with the Generic HTTP Advanced Controller to a Prometheus Pushgateway but got an error because the controller plugin adds a "\r" at the end of the body line, also if its only one line.
The Prometheus Pushgateway on the other side has limitations:
"Note that in the text protocol, each line has to end with a line-feed character (aka 'LF' or '\n'). Ending a line in other ways, e.g. with 'CR' aka '\r', 'CRLF' aka '\r\n', or just the end of the packet, will result in a protocol error."
So my question is, is there a way to customize the body in some way to meet "only \n" requirement?
I did a custom build already, but I do not find the function I have to change or maybe someone was in the same situation and found a workaround?
Also I tried sending binary and sending without binary option checked... it does not make a difference.
I was building from "mega" branch yesterday.
Hopefully I provided all the necessary information ...
Information Pushgateway: https://github.com/prometheus/pushgatew ... /README.md
Many thanks in advance!
All the best,
Philipp
HTTP Advanced Controller to Prometheus Pushgateway
Re: HTTP Advanced Controller to Prometheus Pushgateway
I found a solution after some deeper investigation...
So what happens is that if you send a body without a newline inside the gui whether \n nor \r is sent.
If you enter a newline inside the gui both is appended.
Therefore the solution is do not append a newline but append %LF% after your metric.
eg: some_metric 4.3%LF%
Keep an eye on not inserting a newline.
Also activate the checkbox for Send Binary.
All the best
Philipp
All the best
Philipp
Is this specific to this host, or is it according to some standard we should have to follow?
Maybe I can also add an option to explicitly send only \n and force to send at least once ?
