Hi all!
I wanted to add INA219 devices to ESPEasy. One of the given device has the bus address 0x42 and is properly recognized by I2C Scan option (under Tools), but for defining new I2C INA219 only the given addresses 0x40, 0x41, 0x44 and 0x45 are selectable, although the range of possible addresses is much bigger.
Is there a possiblility to adapt the selection box?
br
Alex
Only 4 I2C Addresses offered in the selection box for new INA219 devices
Re: Only 4 I2C Addresses offered in the selection box for new INA219 devices
Currently that plugin only supports these 4 most used I2C addresses, can you re-configure the board to use any of the supported addresses?
I've created a pull request #3994 to add support (and a documentation table) for all 16 possible I2C addresses.
The PR #3994 has been merged, you can get a test-build from the Github Actions pages, or wait for a next Releae of ESPEasy, where it will then be included.
Thank you for the quick solution. Indeed, I need up to 7 I2C addresses, so it will be fine to select all of the 16 addresses.
Users browsing this forum: Bing [Bot], Google [Bot] and 55 guests
