I have installed ESP_Easy_mega_20211224_normal_ESP8266_4M1M Dec 24 2021 on my wemos d1 mini.
I have set a sleep mode 300 sec sleep 10 awake.
I use it as weather station with 5 sensors and send it to domoticz.
I see that the wemos not send the data at once in the window of 10 seconds.
Is there a setting for this?
Send data at once
Re: Send data at once
The common way to send multiple sensor values closely together is to run the task explicitly, best triggered at wifi#connected, and allowing a few seconds for the controllers to send out their values, something like this:
I've added support for a bypass switch, so regular maintenance can be done on the unit, by pulling a GPIO pin to gnd
on WiFi#Connected do // We are connected (takes a few seconds), now send out data
taskrun,sensor1 // Use current tasknames
taskrun,sensor2
taskrun,sensor3
taskrun,sensor4
taskrun,sensor5
TimerSet,1,3 // Allow a few seconds to get all data out before going to sleep
on Rules#Timer=1 do
if [Bypass#State]=1 // Bypass switch not engaged
DeepSleep,300
where can i put the script
You will have to enable Rules option in Tools/Advanced, then the Rules tab will be visible in the webpage, between Devices and Notifications (or Tools on builds that don't have notifiers)
Thanks, I will test it.
Users browsing this forum: No registered users and 122 guests
