How to set up value open/close
Posted: 20 Mar 2022, 13:11
by nobody@all
Hi. Is it possible using Switch input - Switch to set value Open/Close not 0/1?
I'm trying to do the door lock status sending via mqtt to Nettemp. In nettemp i can receive status open/close.
Re: How to set up value open/close
Posted: 20 Mar 2022, 14:31
by Ath
The use of variables supports formatting like that, as documented here:
https://espeasy.readthedocs.io/en/lates ... red-values
so, your rule could use it like this:
on switch#state do // Adjust switch and state to the name of your Device task
Publish,topic/goes/here,[switch#state#C#c] // Adjust also when applicable, sends 'Close' and 'Open' ('C' transformation), with first character capitalized, rest in lower case because of the 'c' justification
NB: If you want to send a 'state' (Closed/Open) instead of an 'action' (Close/Open) the 'C' transformation should be changed to 'c'.
If 0 means open, and 1 means close, then the transformation should be prefixed with an exclamation mark, so '!C' or '!c' (no quotes should be used for the transformation in the actual rules code, that's just added for readability)
It is currently not (easily) supported to send a transformed value to a controller, so the Controller checkbox on the task should be disabled, as it is sent from rules now.
Posted: 21 Mar 2022, 22:25
by nobody@all
thank You! I will try:)
Posted: 29 Mar 2024, 00:18
by nobody@all
after almost one year
i have back to this topic.
In link which you posted I found what you meaned.
C: 0 => “CLOSE” 1 => “ OPEN”
c: 0 => “CLOSED” 1 => “ OPEN”
I have been tried something like this:
on Door_sensor#State do
Publish,homedoor_1,Door_sensor,State,[switch#state#C]
but in [switch#state#C] i have nothing.
1280172: EVENT: Door_sensor#State=0
1280187: ACT : Publish,homedoor_1,Door_sensor,State,
1284790: EVENT: Door_sensor#State=1
1284801: ACT : Publish,homedoor_1,Door_sensor,State,
- mqtt no status.jpg (70.03 KiB) Viewed 1295 times
What I'am missing?
Posted: 29 Mar 2024, 07:43
by Ath
nobody@all wrote: ↑29 Mar 2024, 00:18
2022, that's even 2 years ago
What I'am missing?
Well, that's to be expected, your switch is called Door_sensor...
This should work:
Publish,homedoor_1,Door_sensor,State,[Door_sensor#state#C]
Posted: 29 Mar 2024, 11:37
You might also need to use quotes as the " OPEN" has a space in it.
And you have too many commas for the MQTT topic.
Typically you have to use / as separator for topic levels.
Publish,homedoor_1/Door_sensor/State,"[Door_sensor#state#C]"
Maybe this is better:
if %eventvalue%=0
Publish,homedoor_1/Door_sensor/State,CLOSE
Publish,homedoor_1/Door_sensor/State,OPEN
Posted: 31 Mar 2024, 00:36
by nobody@all
I finally know why my wife is always angry at me - I think I'm doing it quickly but in real two year passed like a one day
this code
if %eventvalue%=0
work great. thank You
Posted: 31 Mar 2024, 00:53
You're welcome
