how can I "install" following Soil Moisture Sensor in ESPEasy?
https://de.aliexpress.com/item/32666789 ... uEsVe&mp=1
Re: Soil Moisture Sensor
When using the Analog output (AO) you can connect that to the Analog input of ESPEasy. Be sure to not use a VCC build, as that uses the analog input for measuring the VCC.
When using the Digital Output (DO) you can use any normal GPIO that allows input, and use a Switch device to get the state, or set up a monitor command for that pin, to be handled in rules.
Users browsing this forum: Google [Bot] and 37 guests
