help on rules from tasmota to espeasy
megamarco83
#1 Post by megamarco83 » 12 Feb 2022, 17:51
hi, i have a push button that is now on a tasmota device that make this:
when it's single press => send command to power on the light => publish cmnd/dimmer/power TOGGLE
when it is first time longpress => send the command to increase the dimmer => cmnd/dimmer/DIMMER +
when it is second time longpress => send the command to decrease the dimmer => cmnd/dimmer/DIMMER -
then the third time come back to "+" and so on.
of course it continue to send the command "+" or "-" till the duration of the pressing
the actual rule that manage it in tasmota is:
rule2 ON system#boot DO Backlog var1 +; var2 1 ENDON
ON switch1#state=2 DO publish cmnd/dimmer/power TOGGLE ENDON
ON switch1#state=4 DO publish cmnd/dimmer/DIMMER %var1% ENDON
ON switch1#state=7 DO mult2 -1 ENDON
ON var2#state==-1 DO var1 - ENDON
ON var2#state==1 DO var1 + ENDON
ON dimmer#state==1 DO mult2 -1 ENDON
ON dimmer#state==100 DO mult2 -1 ENDON
how i can menage it with espeasy now?
for short press to toggle the power is very easy, but how i can perform that fist time that i longpres it published
//continue feeding this command still i continue to press the button
and second time that is longpressed will publish
the third time taht is longpressed publish
the fourth time that is longpressed publish
and so on?
thanks
lindadieggoo
Re: help on rules from tasmota to espeasy
#2 Post by lindadieggoo » 24 Feb 2022, 04:33
it's a complex piece of code. Did you find the solution? drift hunters
megamarco83
#3 Post by megamarco83 » 24 Feb 2022, 09:26
lindadieggoo wrote: 24 Feb 2022, 04:33 it's a complex piece of code. Did you find the solution? drift hunters
hi, unfortunately not ;(
i'm still using tasmota for this device but i would like to move on espeasy because i have already an esp with espeasy that control other relays...
to control the push button when it's single press => send command to power on the light => publish cmnd/dimmer/power TOGGLE it's very easy, so no matter here
the difficulties are on:
when it is first time longpress => continuously send the command to increase the dimmer (that should continuously sending this command till i maintain pressed the push button), that's => publish cmnd/dimmer/DIMMER +
when it is second time longpress => continuously send the command to decrease the dimmer (that should continuously sending this command till i maintain pressed the push button), that's => publish cmnd/dimmer/DIMMER -
chromo23
#4 Post by chromo23 » 26 Feb 2022, 21:42
On Button#State=1 do
  timerSet_ms,1,300
On Rules#Timer=1 do
 if [Button#State]=0
  event,toggle
   timerSet,2,1
On Rules#Timer=2 do
 if [Button#State]=1
   if [var#1]=0
    //your code for dimmercommand+ here
    //your code for dimmercommand- here
   timerSet_ms,2,1000
   let,1,![var#1]
megamarco83
#5 Post by megamarco83 » 28 Feb 2022, 11:32
chromo23 wrote: 26 Feb 2022, 21:42
  timerSet_ms,1,300
On Rules#Timer=1 do
 if [Button#State]=0
  event,toggle
   timerSet,2,1
On Rules#Timer=2 do
 if [Button#State]=1
   if [var#1]=0
    dimmercommand+
    dimmerecommand-
   timerSet_ms,2,1000
   let,1,![var#1]
hi, thanks for your suggestion!!!
starting from this i use the internal function of longpress(task=10) and shorpress (task=0)
i report here the code:
on pcf_73_camera_dx#State do
if [pcf_73_camera_dx#State]=10
 event, dimmer
   let,1,![var#1]
  if [pcf_73_camera_dx#State]=0
  event,toggle
   let,1,![var#1]
On event#dimmer do
   if [var#1]=0
    dimmercommand+
    dimmerecommand-
On toggle do
  Publish cmnd/dimmer/power1,'2' // tasmota toggle luce dimmer cameraDX
On dimmercommand+
  Publish cmnd/dimmer/dimmer,'+' // tasmota dimmer+ luce dimmer cameraDX
On dimmercommand-
  Publish cmnd/dimmer/dimmer,'-' // tasmota dimmer- luce dimmer cameraDX
but there is an issue, with shortpress no matter => it works
but longpress espeasy not send out the command for dimmering + or dimmering -
can you help me on understand why?
below the log
689129374: PCF : Port=73 State=0 Output value=0
689129387: EVENT: pcf_73_camera_dx#State=0.00
689129517: ACT : let,1,!0.00
689129519: Command: let
689129527: ACT : event,toggle
689129528: Command: event
689129528: EVENT: toggle
689129628: ACT : Publish cmnd/dimmer/power1,'2'
689129630: Command: Publish
689130469: PCF : LongPress: Port= 73 State=0 Output value=10
689130475: EVENT: pcf_73_camera_dx#State=10.00
689130573: ACT : let,1,!1.00
689130575: Command: let
689130582: ACT : event,toggle
689130583: Command: event
689130584: EVENT: toggle
689132462: ACT : Publish cmnd/dimmer/power1,'2'
689132464: Command: Publish
689132809: WD : Uptime 11486 ConnectFailures 4 FreeMem 16200 WiFiStatus 3
689133399: PCF : Port=73 State=1 Output value=1
689133411: EVENT: pcf_73_camera_dx#State=1.00
689133487: ACT : let,1,!0.00
689133489: Command: let
689133500: ACT : let,1,!1.00
689133501: Command: let
chromo23
#6 Post by chromo23 » 28 Feb 2022, 13:01
hi,
my code it somewhat "oldschool" because there was an issue with longpress in the past. it seems to be fixed now...
your code is not quite right. to call an event you have to do it like this:
event, dimmercommand+  //not so good
event, dimmerplus //better
...and it is always good to avoid characters like + because they serve a function in rules (i used it only as pseudocode....fixed it in the last post)
to react on an event it is simply:
On dimmer do
so it should be:
 event,dimmer
   let,1,![var#1]
  event,toggle
   let,1,![var#1]
On dimmer do
   if [var#1]=0
    event,dimmerplus
    event,dimmerminus
On toggle do
On dimmerplus do
On dimmerminus do
megamarco83
#7 Post by megamarco83 » 28 Feb 2022, 13:46
chromo23 wrote: 28 Feb 2022, 13:01
On dimmer do
so it should be:
thanks again for support, really appreciated!
i apply your suggestion but it seams that the rules for longpress are wrong.
here the logs:
418841: PCF : Port=73 State=0 Output value=0
418847: EVENT: PCF#73=0
419075: EVENT: pcf_73_camera_dx#State=0
419191: ACT : let,1,!1
419207: ACT : event,toggle
419209: EVENT: toggle
419337: ACT : Publish cmnd/dimmer/power1,'2'
419901: PCF : LongPress: Port= 73 State=0 Output value=10
419904: EVENT: PCF#73=10
420135: EVENT: pcf_73_camera_dx#State=10
420251: ACT : let,1,!0
420265: ACT : event,toggle
420267: EVENT: toggle
420402: ACT : Publish cmnd/dimmer/power1,'2'
424780: PCF : Port=73 State=1 Output value=1
424786: EVENT: PCF#73=1
424935: EVENT: pcf_73_camera_dx#State=1
425050: ACT : let,1,!1
425068: ACT : let,1,!0
if i longress the light turn on and then after a second it torn off without dimmering.
unfortunately the command that tasmota expect to receive trought mqtt is:
topic = cmnd/dimmer/dimmer
payload = +
or
payload = -
but it seams from the log that it's not a matter of publishing (+) or (-) because espeasy send nothing....isn't it?
thanks for help again
p.s. here the code:
 event,dimmer
   let,1,![var#1]
  event,toggle
   let,1,![var#1]
On dimmer do
   if [var#1]=0
    event,dimmerplus
    event,dimmerminus
On toggle do
On dimmerplus do
On dimmerminus do
chromo23
#8 Post by chromo23 » 28 Feb 2022, 14:05
can you please test my code?
on pcf_73_camera_dx#State=0 do
  timerSet_ms,1,300
On Rules#Timer=1 do
  event,toggle
   timerSet,2,1
On Rules#Timer=2 do
   if [var#1]=0
    event, dimmerplus
    event, dimmerminus
   timerSet_ms,2,1000
   let,1,![var#1]
On toggle do
On dimmerplus do
On dimmerminus do
edit: my code is firing dimmerplus ore dimmerminus every second while holding the button...it is intentionally. but now i am not sure if i understood you correctly.
if only once it should be (untested):
On Rules#Timer=2 do
   if [var#1]=0
    event, dimmerplus
    event, dimmerminus
    let,1,![var#1]
megamarco83
#9 Post by megamarco83 » 28 Feb 2022, 15:45
chromo23 wrote: 28 Feb 2022, 14:05 can you please test my code?
  timerSet_ms,1,300
On Rules#Timer=1 do
  event,toggle
   timerSet,2,1
On Rules#Timer=2 do
   if [var#1]=0
    event, dimmerplus
    event, dimmerminus
   timerSet_ms,2,1000
   let,1,![var#1]
On toggle do
On dimmerplus do
On dimmerminus do
yes, of course. thanks for your kindness.
i tested it, and it works perfectly!!!
chromo23 wrote: 28 Feb 2022, 14:05 edit: my code is firing dimmerplus ore dimmerminus every second while holding the button...it is intentionally. but now i am not sure if i understood you correctly.
you understand correctly: when i dim, i need to continue feed the command:
or
and your code is according to this: till i press the button it send coniusoly (every seconds) => timerSet_ms,2,1000
so it's very good working.
i not understand why using longress plugin (instead of timers) it not works :(
#10 Post by Ath » 28 Feb 2022, 15:57
megamarco83 wrote: 28 Feb 2022, 15:45 i not understand why using longress plugin (instead of timers) it not works :(
LongPress event is generated only once, and not repeating if the button is being pressed for prolonged time.
Sminter4
#11 Post by Sminter4 » 04 Jan 2024, 15:34
I have a similar problem. When I query for "longpress" (11) or "Doubleclick" (3), %eventvalue1%=1 is always output first. This means I always get two commands instead of one.
How can I prevent this without a timer?
For example:
on drei#state do //Rolladen
 LongPulse_mS,14,1,100
 if [drei#state]=1
   http://192.168.178.109/roller/0?go=open
  if [drei#state]=11
   http://192.168.178.109/roller/0?go=close
