Nice housing or ready made with good WAF
Posted: 10 Jan 2022, 19:28
by HomeJCL
Just found this, readymade setup
https://www.kincony.com/kc868-uair-esp ... eased.html with ESP32
Or also interesting the housing (naked)
https://www.aliexpress.com/item/330406 ... 6c37034tAs most interesting not limited to their specific print size, both shells have 4 studs for screw fixing of prints
Very high WAF factor :
Re: Nice housing or ready made with good WAF
Posted: 10 Jan 2022, 21:23
Looks really nice indeed.
And also the enclosure looks quite good. Too bad it has openings for mini USB, but that's probably why it is so cheap
Too bad they don't list it with ESPEasy...
https://www.aliexpress.com/item/1005003740881856.html
Posted: 14 Mar 2022, 09:58
by vincen
My advice is to stay away of that device ! Have one here and it's chinese bad design
- One of the ring/base LED is wired with bar LED which kills the visual effect of product
- Temperature sensor inside is not an original Dallas temp sensor (4/5° offset with my other sensors aronud !).
- support of manufacturer is very bad.
Posted: 13 Nov 2023, 10:35
by jgrad
have anybody sucessfully installed ESP32 version of ESPEASY on this board?
This board is interesting for me as "ready made of-the-shelf HW" with digital I/O and wired Ethernet.
Posted: 13 Nov 2023, 10:39
I have not, but seems like all onboard except for the RF modules should work just fine.
Posted: 13 Nov 2023, 11:19
by Ath
jgrad wrote: ↑13 Nov 2023, 10:35
Not sure where you have found the wired Ethernet connection, I can only see 2 mini-USB connectors installed
And AFAICS, the available GPIO pins don't allow for an Ethernet module to be connected, as some of the required/fixed ETH GPIOs are in use by other things.
Posted: 13 Nov 2023, 11:27
by jgrad
Posted: 13 Nov 2023, 11:46
by vincen
That one works really well with ESPHome so it should be all good with ESPEasy too
I have quite a few installed at some customers !
Posted: 13 Nov 2023, 12:45
by jgrad
@vincen
thanks for feedback - I ordered one to try first device with wired ethernet in combination with ESPeasy.
Posted: 13 Nov 2023, 13:04
by Ath
Ah, ok, indeed, all except the 433 MHz sub-boards seem to be supported. I do have support for such 433 MHz boards on my TODO list though...
