Neopixel Basic P038 Multiple instances
Posted: 10 Jan 2022, 18:00
by HomeJCL
Subject sums it all.
Is it possible to have multiple NeoPixel Basics plugins running ?
I have access to both of the strips but only with 1 instance in Devices.
At time, it is one or the other.
Not that it is crucial.
Re: Neopixel Basic P038 Multiple instances
Posted: 10 Jan 2022, 18:32
Posted: 10 Jan 2022, 19:22
by HomeJCL
Need to up my configuration skills in the meantime
Posted: 11 Jan 2022, 20:18
by Ath
I've created a pull request
#3909 to add multi-instance as a feature for the NeoPixel (Basic) plugin (P038).
Most likely the Github action builds won't complete, what .bin file are you using?, then I'll upload that build here.
Posted: 11 Jan 2022, 21:48
by HomeJCL
Tried all of them, standard would be ESP_Easy_mega_20211224_normal_ESP32_4M316k
Posted: 11 Jan 2022, 23:22
by Ath
A local build for PR #3909, that should allow multiple NeoPixel (Basic) tasks to be configured and controlled separately:
Posted: 12 Jan 2022, 08:24
by HomeJCL
It works … when you address the right one
Many thanks.
Can make time for the application now. Hopefully my part goes as slick as your support
For the record
https://espeasy.readthedocs.io/en/late ... f-a-plugin
Posted: 12 Jan 2022, 08:57
by Ath
Thanks for testing, and the confirmation
Posted: 12 Jan 2022, 19:40
by HomeJCL
Does this means standard implementation in future releases ?
Thanks again.
The Mrs asked for other stuff.
Technology when it works : goes from pfff superfluous to can you also do this
Posted: 12 Jan 2022, 19:58
by Ath
Yes, this is one of the plugins in the NORMAL builds, so it will be in nearly all available builds once it is merged and released (well, 'max', 'normal' and 'test' that is, the minimal and hardware specific builds don't have this plugin included).
Posted: 02 Mar 2023, 18:45
by HomeJCL
Just tried to update an old setup.
Seems P038 multiple instances is no longer "working" in release after 20220427.
I have tried, I think all of them, after this release date, but no success.
Can you confirm ?
Posted: 02 Mar 2023, 19:00
by Ath
There is no reason for that, has been tested recently here, so should work fine.
Posted: 13 Mar 2023, 19:15
by HomeJCL
Hi Erased and Erased more, pushed an “empty” file … and succes
Sorry for late reply, ESP is a testbed for a lot of things and for some reason I tested another platform, which left crumbles to make me think ESPEasy was the solution.
Mae culpa …
I believe again and even more
ESPEasy is alive again
