MCP23017 - read pin state [plugin#mcpgpio#pinstate#1]
Posted: 28 Nov 2021, 21:24
by johndoe39274
Hey,
I'm running ESP Easy on a Wemos D1 mini Pro, connected through MQTT to OpenHAB, and with 2 MCP23017's hooked up through I²C. I can control the inputs and outputs of the MCP's just fine from OpenHAB, so I know my hardware is working.
I am trying to set up a local Rule to trigger on mcp#17 (=MCP
0x21 PA0) and toggle the state of output mcpgpio,1 (=MCP 0x
20 PA0) . This is my code:
on System#Boot do
Monitor MCPGPIO,17 // monitor pin for state changes
on mcp#17 do
Publish,%sysname%/Debug/OnMcp17,"on mcp#17 triggered" //debug message 1
Publish,%sysname%/Debug/OnMcp17,[plugin#mcpgpio#pinstate#1] //debug message 2
if [plugin#mcpgpio#pinstate#1]=1 //LED is off
Publish,%sysname%/Debug/IfPinState,"[plugin#mcpgpio#pinstate#1] triggered 1" //debug message 3
mcpgpio,1,0 // set LED on
if [plugin#mcpgpio#pinstate#1]=0 //LED is on
Publish,%sysname%/Debug/IfPinState,"[plugin#mcpgpio#pinstate#1] triggered 2" //debug message 4
mcpgpio,1,1 // set LED off
When I press the button mcp#17 I can see debug messages 1 and 2 coming in over MQTT. I do NOT see messages 3 nor 4...
The value of
[plugin#mcpgpio#pinstate#1] in debug message 2 is "" , which resolves to some UTF or ASCII encoding for "SOH"... I don"t understand this result. Shouldn't
[plugin#mcpgpio#pinstate#1] return a 0 or 1 depending on the pin state low or high?
If not, how can I test if my MCP output pin is high or low so I can toggle it?
Running build ESP_Easy_mega_20211105_normal_beta_ESP8266_16M_LittleFS Nov 5 2021
Thanks in advance!
- John
Re: MCP23017 - read pin state [plugin#mcpgpio#pinstate#1]
Posted: 29 Nov 2021, 00:51
Not entirely sure if this makes the difference (have to look into the code, but I decided to go to bed like 15 mins ago....)
See:
https://espeasy.readthedocs.io/en/lates ... task-names
[Plugin#MCP#Pinstate#N] to get the pin state of a MCP pin.
You're using not "MCP" but "mcpgpio"
Maybe you can try as is mentioned in the docs?
Also you may also monitor that pin as I'm not sure if the pinstate is known if it isn't monitored.
Posted: 01 Dec 2021, 09:54
by johndoe39274
Thanks for the reply and for the pointers! Going to bed is never a bad idea
I'm afraid it doesn't work though. Either pin state monitoring doesn't work, or the Pinstate#1 doesn't return an expected value. Given the fact that
on mcp#17 do does trigger correctly, I would assume pin monitoring is working.
I tried these variations of the monitor command but with no ultimate success:
Monitor,MCP,1 // monitor pin for state changes
Monitor,MCPGPIO,1 // monitor pin for state changes
Monitor MCP,1 // monitor pin for state changes
Returns the strange SOL character instead of the expected value of 0 or 1:
Publish,%sysname%/Debug/Mcp17value,mcp#17
This one triggers correctly:
Both return the strange SOL character instead of the expected value of 0 or 1:
Publish,%sysname%/Debug/OnMcp17,[Plugin#MCP#Pinstate#1]
Publish,%sysname%/Debug/OnMcp17,[Plugin#MCPGPIO#Pinstate#1]
Both conditions do not pass (same for condition =0 instead of =1):
if [Plugin#MCP#Pinstate#1]=1 //LED is off
if [Plugin#MCPGPIO#Pinstate#1]=1 //LED is off
The documentation seems to confuse between the use of MCP and MCPGPIO. I can't wrap my head around it and make it work.
Would anyone have a snippet of working code for testing pin status with MCP23017 IO please?
Posted: 02 Dec 2021, 09:17
by leel1967l
Hi @johndoe39274,
I am using the 20211105 version and I am using the following snippet:
on System#Boot do
mcpgpio,1,1
monitor,mcp,1
on mcp#1 do
publish %sysname%/Relay/r1,=[PLUGIN#MCPGPIO#PINSTATE#1]
The only difference I see is that I am using the normal 4M version and not the 16M, beta, LittleFS version.
Please try this:
1) Add the following in the system#boot section:
2) In the TOOLS page, enter the following command, check the result in the log and report here the results:
logentry,[plugin#mcpgpio#pinstate#1]
logentry,[plugin#mcpgpio#pinstate#17]
3) Finally, is there a chance you could test the following version: ESP_Easy_mega_20211105_normal_ESP8266_4M1M.bin ?
Posted: 02 Dec 2021, 10:12
by Ath
leel1967l wrote: ↑02 Dec 2021, 09:17
Please try this:
Shouldn't that be like this: ?
The ESP8266 16M build uses the same Arduino release and compiler flags, so that shouldn't make a difference, other than the file system being LittleFS instead of SPIFFS, and that shouldn't be of
any influence on the handling of plugins.
Posted: 02 Dec 2021, 15:48
by leel1967l
The MONITOR command accepts both MCP or MCPGPIO, it doesn't matter.
I was suggesting to try a diferent bin version, because in my setup the monitor and the [plugin#mcpgpio#pinstate#1] commands work.
Posted: 02 Dec 2021, 16:57
by johndoe39274
Thanks for the replies! Based on your suggestions and code I did some more troubleshooting. The following code works, but I have no idea why:
on System#Boot do
monitor,mcpgpio,17 // monitor pin for state changes
// monitor,mcpgpio,1 // monitor pin for state changes (it works with or without this line)
on mcp#17 do
if [plugin#mcpgpio#pinstate#17]=0 //button pressed
else //LED is on
Posted: 03 Dec 2021, 10:45
by leel1967l
If I am not wrong you cannot have nested if..else..endif.
Maybe @TD-er can clarify this.
Posted: 03 Dec 2021, 10:50
You can have nested if's, only there is a limit to it.
