Hello! I'm new to using EspEasy. I've been trying to figure it out for a few days, but I can not do anything. My task is simple. There is 1 switch. With this switch I want to operate 2 relays. By means of short and long pressing of the button. Switch is a simple press button. I can do it with the help of this rule:
on sw1#value1 do
if [sw1#value1] = 0
timerSet, 1, 1
on rules#timer=1 do
if [sw1#value1] = 1
But there is a problem - too long delay with a short press. A whole second. And it's very inconvenient. I have read that for timerSet you can not use a value of less than 1 second. I read about the delay function. I'm trying to use it instead of timerSet, but nothing happens. Maybe someone can help me?
Long press button delay
Re: Long press button delay
There is a mishap in your code, the endif is missing after timerSet,1,1
Documentation on rules is here: https://espeasy.readthedocs.io/en/lates ... Rules.html
And besides the timerSet command there is also a timerSet_ms that has a milliseconds argument instead of a seconds argument, giving finer control.
The complete list of commands is here: https://espeasy.readthedocs.io/en/lates ... mmand.html
You could also react to the event value 10 or 11 when the longpress is activated, as documented in the comboboxes on the Switch settings.
on sw1#value1 do
if [sw1#value1] = 0
timerSet, 1, 1
on rules#timer=1 do
if [sw1#value1] = 1
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 32 guests
