BlueDot Sensor (BME280 + TSL2561) - no Lux [Solved]
Posted: 17 Nov 2021, 21:00
by oisisi
I have a
breakout board which includes a BME280 and a TSL2561 sensor. An I2C scan shows both sensors and their respective addresses (0x77 and 0x29). The BMEx280 plugin works as expected, the TSL2561 plugin shows no values. How can I trouble shoot this further?
Re: BlueDot Sensor (BME280 + TSL2561) - no Lux
Posted: 17 Nov 2021, 21:12
by Ath
Have you tried setting the TSL2561 to use the Slow I2C speed (and left that Hardware setting on its default 100 kHz)?
Posted: 17 Nov 2021, 21:14
by Ath
Ah, the imprint on the board says TSL2591, so you'll have to use that plugin, as they TSL2561 plugin isn't compatible with the TSL2591 (but I can understand your confusion
). You'll need a Test_A build to have both plugins available.
Posted: 17 Nov 2021, 21:44
by oisisi
Duh, thanks. I apparently had a dyslexic moment and didn't notice the upside-down '6'.
I guess I'll have to mix a custom image once again.
Posted: 17 Nov 2021, 21:53
by oisisi
I'm not alone, it seems in Custom-sample.h the necessary plugin is also mislabeled:
- Code_kvk9BcfcV5.png (2.71 KiB) Viewed 7320 times
Posted: 17 Nov 2021, 22:10
by oisisi
Ath wrote: ↑17 Nov 2021, 21:14
A quick compile and flash later:
- firefox_qjKowGeERH.png (10.13 KiB) Viewed 7318 times
Thank you Ath, once again.
Posted: 17 Nov 2021, 22:22
by Ath
We're all only human
Posted: 17 Nov 2021, 22:28
by TD-er
Ath wrote: ↑17 Nov 2021, 22:22
... /me looks at your avatar...
Sure
Posted: 17 Nov 2021, 22:47
by Ath
TD-er wrote: ↑17 Nov 2021, 22:28
Sure
ROFL
