How to program a pulse if input goes to high and same pulse when input goes low
Posted: 15 Nov 2021, 18:23
by BartSr
In dutch we call this a veegcontact.
Google translate says passing contact.
Can we have a pulse on output if an input goes high and then, once input goes low a pulse again?
Thanks for your help.
Bart
Re: How to program a pulse if input goes to high and same pulse when input goes low
Posted: 15 Nov 2021, 23:08
by TD-er
So you want an event on the "rising" and "falling" edge of the pulse?
This can be done using the switch plugin and some small rules.
The Switch should be set to "Normal Switch", as it will send an event on every state change.
You can even add some filtering if you like to suppress any bouncing ("anti-dender schakeling" in Dutch
As an example, you create a task with the "Switch input" plugin and name it "veeg"
With the default variable name "State" you will get 2 events:
veeg#State=0
veeg#State=1
So in the rules you can act on the veeg#State event and keep track of the state using a variable.
on veeg#state do
if %eventvalue1% = 0
// Do stuff when the veegcontact is entered
// Do stuff when the veegcontact is exited
Posted: 16 Nov 2021, 02:19
by ThomasB
And for those sitting in the peanut gallery, this use case can use a simpler event rule:
on veeg#state do // Contact has opened or closed.
// Do stuff here. Will be the same for open or close.
But when the rule must act differently (open rule actions different from close rule actions) then follow the example provided by @TD-er.
Posted: 17 Nov 2021, 09:58
by BartSr
I see how to act once an inputstate changes but how to hook this onto an output in way that that output is activated for e.g. 500 MiliSeconds (pulse)?
Posted: 17 Nov 2021, 10:05
by TD-er
This can be done in 2 ways:
Either set the debounce to 500 msec, so everything less will be ignored.
Or enable to send a longpress event
For the longpress event, depending on your selection, the %eventvalue1% will be either 10 or 11 when a longpress is detected.
Posted: 17 Nov 2021, 11:00
by BartSr
TD-er,
Once again thanks for reply. But IMHO using the debounce-time makes no sense as it should be the otheway around. Once the output has been activated by change of an inputstate the output must be activated immediately for just 0,5 sec. By using debounce the output is just delayed as log as debounce-time is set. If input has been de-activated same must happen. Output must be activated for 0,5 sec.
Or did I understood the 'debounce-time' wrong?
Thanks,
-Bart
Posted: 17 Nov 2021, 13:46
by TD-er
Nope, you've got it right.
So that leaves the "long press" feature.
N.B. you can combine both, like 50 msec for the debounce and 500 msec for the long press.
Just check for the %eventvalue1% value to see which event you're handling (there may be multiple)
Posted: 17 Nov 2021, 18:58
by ThomasB
I'm a bit confused. The questions seem to concern the output pulse, but the discussion is centered on the input trigger. Although both are involved in your application, those are two different actions.
I seems that you want to send a 500mS pulse on an output pin when some other input pin changes state. If that is the case, then the event rule discussed earlier would simply call LongPulse_ms.
The LongPulse_ms command is described in the ESPEasy Command docs.
https://espeasy.readthedocs.io/en/lates ... mmand.html
Command excerpt shown below:
LongPulse_ms,<GPIO>,<state>,<duration>
GPIO: 0 … 16
State: 1/0
Duration: 10 … 15000 msec
To send a *long* pulse to a certain pin. A LongPulse_mS is the same as the regular LongPulse.
The only difference is the time base in milliseconds rather than in seconds.
Let's say you want to generate an active high pulse on GPIO14 for 500mS when an Switch Input named "veeg#state" is opened or closed. Here is an example rule (you would need to change it to match your pin definitions).
LongPulse_ms,14,1,500 // Send pulse on Open or Close.
