Email notification on Low Battery Voltage [notify in rules]
Posted: 14 Nov 2021, 12:22
by fm-maniac
In short, here's what I want to do:
The ESP8266 should send an Email when the battery voltage (measured externally on ADC) goes below a defined value.
First I set up notification #1. This is working properly. At least when clicking "test" the defined Email is sent!
Next I activated rules in the config and setup a simple rule:
I expected that the Email will be triggeres on each reboot. But nothing happens. What am I doing wrong?
Re: Email notification on Low Battery Voltage [notify in rules]
Posted: 14 Nov 2021, 13:07
by TD-er
System boot may be too early to send out an email as the network is not yet connected.
See the WiFi#Connected event:
https://espeasy.readthedocs.io/en/lates ... ore-events
Posted: 14 Nov 2021, 16:40
by fm-maniac
Thanks TD-er for your helpful reply!
I changed the rule to:
on WiFi#Connected do
notify 1
and now the Email notification is triggered after reboot. BTW: My first approach was given as an example here:
https://www.letscontrolit.com/wiki/inde ... tification.
Next I triggered the notification by the battery voltage getting below 3.5V:
on BatteryMon#Ubat<3.5 do
notify 1
Thing is that the notification is triggered on each measurement below 3.5V (each 30s as setup in the device config).
What I would like to achive is to have this triggered only once (er even better once a day) as long as the value stays below 3.5V. This becomes even more complicated as the ESP is send to sleep mode after 30s of operation and wake up after 300s.
So I need to set a flag, log entry or something similiar that endures the sleep mode and can be used as condition for an if/else clause.
May I get some hints on how to achive this? some starting points for further investigations? That would be highly appreciated!
Posted: 14 Nov 2021, 17:32
by fm-maniac
I meanwhile found this
thread
proposing this code:
on Batterie#Spannung do
if %eventvalue%<2.5 and [var#1]=0
notify 1
let,1,1
if %eventvalue%>2.5
let,1,0
Unfortunatly this doesn't work while the ESP is put in sleepmode because of the variable not being properly initiated.
Posted: 14 Nov 2021, 18:24
by TD-er
You can also use a dummy task and store the values in this dummy task value using taskvalueset.
https://espeasy.readthedocs.io/en/lates ... skvalueset
As long as the ESP remains powered, the task values are stored in RTC memory and restored at boot.
Posted: 21 Nov 2021, 15:51
by fm-maniac
I would like to follow up on this. I set up a dummy device called "Notification" with a variable "SendFlag" and created the following rule:
on BatteryMon#Ubat do
if %eventvalue%<3.5 and [Notification#SendFlag]=0
notify 1, "The current battery voltage is: [BatteryMon#Ubat]V"
TaskValueSet Notification,SendFlag,1 // Set Send Flag
if %eventvalue%>=3.5
TaskValueSet Notification,SendFlag,0 // Delete SendFlag
The SendFlag maintains it's value during deep sleep so the notification is sent out only once. But if the battery voltage falls below 3.5V during the deep sleep phase, no notification is sent on the next awake cycle. Although I can observe the SendFlag changing to 1 in the device tab.
3766: NTP : NTP replied: delay 30 mSec Accuracy increased by 0.066 seconds
3769: Time set to 1637505752.066 Time adjusted by 57446.13 msec. Wander: 0.000 msec/second Source: NTP
3773: Local time: 2021-11-21 15:42:32
3775: EVENT: Clock#Time=Sun,15:42
3795: EVENT: WiFi#Connected
3855: EVENT: System#NoSleep=30
3955: EVENT: Time#Set
10335: ADC : Analog value: 528 = 528.00
10352: EVENT: BatteryMon#Ubat=3.30
20335: ADC : Analog value: 528 = 528.00
20352: EVENT: BatteryMon#Ubat=3.30
30335: ADC : Analog value: 528 = 528.00
30353: EVENT: BatteryMon#Ubat=3.30
But it works the other way around when the battery voltage exceeds 3.5V during the sleep phase:
3761: NTP : NTP replied: delay 20 mSec Accuracy increased by 0.120 seconds
3763: Time set to 1637505844.120 Time adjusted by 57505.47 msec. Wander: 0.000 msec/second Source: NTP
3767: Local time: 2021-11-21 15:44:04
3770: EVENT: Clock#Time=Sun,15:44
3789: EVENT: System#NoSleep=30
3856: EVENT: Time#Set
10334: ADC : Analog value: 746 = 746.00
10356: EVENT: BatteryMon#Ubat=4.66
10390: ACT : TaskValueSet Notification,SendFlag,0
20334: ADC : Analog value: 746 = 746.00
20356: EVENT: BatteryMon#Ubat=4.66
20389: ACT : TaskValueSet Notification,SendFlag,0
30334: ADC : Analog value: 746 = 746.00
30404: EVENT: BatteryMon#Ubat=4.66
Any ideas why the Flag chnages to "1" but notification is sent?
Posted: 21 Nov 2021, 16:31
by Ath
Can you add a line: eventlog,"NotificationSendFlag: [Notification#SendFlag]"
in your event handler 'on BatteryMon#Ubat do', before the first 'if', to see what that status really is after returning from deepsleep
Posted: 21 Nov 2021, 16:58
by TD-er
I think the WiFi connection itself may fail or take (much) longer if the battery voltage gets too low.
So you probably hit a timeout or DNS resolve fails.
Posted: 21 Nov 2021, 17:15
by fm-maniac
Ath & TD-er, thanks for supporting me here. This is highly appreciated!
For clarification: The voltage I measure is an additional 2nd voltage from my lab power supply fed by voltage divider to the the ADC for test purpose. The supply voltage of the ESP itself is constant.
30s awake period: Ubat > 3.5V, SendFlag = 0
60s deep sleep period: Ubat change to <3.5V
30s awake period: event handler is entered with sendFlag = 1 -> should only be changed from 0 to 1 on passing the if clause?!
10392: ACT : eventlog,'NotificationSendFlag: 1'
10395: Command unknown: eventlog,'NotificationSendFlag: 1'
BTW: why do I get the Command unknown entires?
Posted: 21 Nov 2021, 17:31
by fm-maniac
Using LogEntry instead of eventlog solves the issue.
Posted: 21 Nov 2021, 17:38
by fm-maniac
>> NetworkError when attempting to fetch resource. <<
5780: WD : Uptime 1 ConnectFailures 0 FreeMem 18176 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
5782: WiFi : Scan not needed, good candidate present
5820: NTP : NTP replied: delay 21 mSec Accuracy increased by 0.478 seconds
5822: Time set to 1637512379.478 Time adjusted by 57806.19 msec. Wander: 0.000 msec/second Source: NTP
5826: Local time: 2021-11-21 17:32:59
5835: EVENT: System#NoSleep=30
5857: EVENT: Time#Set
7249: EVENT: Clock#Time=Sun,17:33
10338: ADC : Analog value: 773 = 773.00
10358: EVENT: BatteryMon#Ubat=4.83
10371: ACT : LogEntry,'NotificationSendFlag: 0'
10374: NotificationSendFlag: 0
10407: ACT : TaskValueSet Notification,SendFlag,0
20335: ADC : Analog value: 773 = 773.00
20360: EVENT: BatteryMon#Ubat=4.83
20373: ACT : LogEntry,'NotificationSendFlag: 0'
20375: NotificationSendFlag: 0
20409: ACT : TaskValueSet Notification,SendFlag,0
30335: ADC : Analog value: 773 = 773.00
30358: EVENT: BatteryMon#Ubat=4.83
30371: ACT : LogEntry,'NotificationSendFlag: 0'
30373: NotificationSendFlag: 0
30409: ACT : TaskValueSet Notification,SendFlag,0
31806: WD : Uptime 1 ConnectFailures 0 FreeMem 17952 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
31807: WiFi : Scan not needed, good candidate present
3461: EVENT: WiFi#ChangedAccesspoint
3578: EVENT: WiFi#ChangedWiFichannel
3635: WIFI : DHCP IP: 192.168.178.50 (ESPeasy-1) GW: 192.168.178.1 SN: 255.255.255.0 duration: 174 ms
3648: WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
3650: firstLoopConnectionsEstablished
3654: EVENT: WiFi#Connected
3677: WD : Uptime 1 ConnectFailures 0 FreeMem 18648 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
3678: WiFi : Scan not needed, good candidate present
3719: NTP : NTP replied: delay 20 mSec Accuracy increased by 0.421 seconds
3722: Time set to 1637512471.421 Time adjusted by 57847.69 msec. Wander: 0.000 msec/second Source: NTP
3726: Local time: 2021-11-21 17:34:31
3728: EVENT: Clock#Time=Sun,17:34
3749: EVENT: System#NoSleep=30
3768: EVENT: Time#Set
10399: ADC : Analog value: 403 = 403.00
10411: EVENT: BatteryMon#Ubat=2.52
10425: ACT : LogEntry,'NotificationSendFlag: 1'
10427: NotificationSendFlag: 1
Posted: 22 Nov 2021, 17:01
by fm-maniac
Nobody having an idea how to solve this?
To monitor the SendFlag I created two additional rules:
on system#boot do
LogEntry,"SendFlag on boot: [Notification#SendFlag]"
on WiFi#connected do
LogEntry,"SendFlag on wifi: [Notification#SendFlag]"
None of this events showed up in the log windows. I assume that at that point of time logging may not be actice?
So is there's a chance that the first event for BatteryMon#Ubat occuring in the log isn't the first one operated? And that on the first operation the notification can't be sent out by any reason?
LogEntry,"SendFlag: [Notification#SendFlag]"
elseif %eventvalue%<3.5 and [Notification#SendFlag]=0
TaskValueSet Notification,Timestamp,%unixday%
Posted: 22 Nov 2021, 17:12
by TD-er
Where do you read the rules?
Given the nature of the events you try to catch, you may only see these log items via serial log.
Posted: 22 Nov 2021, 17:45
by fm-maniac
I'm geeting closer to a solution. I delayed triggering the notification by 5s and now it is sent out on awake when the monitored voltage dropes below the threshold during deep sleep.
TaskValueSet Notification,SendFlag,0 //Delete SendFlag
TaskValueSet Notification,SendFlag,1 //Set Send Flag
timerSet,1,5 //set timer 1 to 5s
on Rules#Timer=1 do
Obviously the rule is processed for the 1st time before WiFi is connected.
Posted: 22 Nov 2021, 19:25
by TD-er
The elseif can be simplified, since the first part is the opposite of the first if part
elseif [Notification#SendFlag]=0
Posted: 22 Nov 2021, 20:22
by fm-maniac
Correct
Please be patient. I'm a old hand hardware guy and still in the learning phase. But this is a good opportunity for me to get more familiar with software and gain my knowledge.
I think I'll choose a different approach by checking the battery voltage once after wifi is connected.
Final use case is gathering data from a bme280 every 5min, sending them to a database and get back to deep sleep in between.
Posted: 12 Dec 2021, 11:42
by fm-maniac
So this it how I currently solved it.
Task was to get the data from an BME280 (temperature, humidity, air pressure) send frequently to the database of my smartmerter (Volkszaehler).
After WiFi is connected data will be send via http. Subsequently I'm doing a two step check of the battery voltage. Below the 1st threshold an early warning is send by Email just once. If the 2nd threshold is cut an alert will be send every defined period (3minutes for testing puposes).
Finally the ESP will be set to deep sleep (60s for testing purposes).
//Send data to Volkszaehler
SendToHTTP,192.168.178.36,80,middleware.php/data/b4a93980-5907-11ec-866f-a7fc10df3363.json?operation=add&value=[BME280#Temperature]
SendToHTTP,192.168.178.36,80,middleware.php/data/a348a0e0-590a-11ec-9669-f7895ee1a54f.json?operation=add&value=[BME280#Pressure]
SendToHTTP,192.168.178.36,80,middleware.php/data/fdf89540-590a-11ec-9fcd-cde54ac6ca54.json?operation=add&value=[BME280#Humidity]
//Calculate timestamp from RTC
Let,1,[Notification#TimestampDay]*86400+[Notification#TimestampSec]
Let,2,3 //set reminder frequency in minutes
if [BatteryMon#Ubat]>=4.0
elseif [BatteryMon#Ubat]<4.0 and [Notification#SendFlag]=0
notify 1, "Early Warning: The battery voltage of your ESP is: [BatteryMon#Ubat]V"
elseif [BatteryMon#Ubat]<3.5 and %unixtime%>[var#1]+[var#2]*60
TaskValueSet Notification,TimestampDay,%unixday%
TaskValueSet Notification,TimestampSec,%unixday_sec%
notify 1, "Alert: The battery voltage of your ESP is: [BatteryMon#Ubat]V"
if [DisablePD#State]=0
timerSet,1,5 //set timer 1 to 5s, wait until notification is sent
on Rules#Timer=1 do
DeepSleep,60 //Send ESP to deep sleep for 60s
Thing is that I have to delay the deep sleep. Otherwise the Email is not send! Although it is reported in the log.
3949 : Info : ACT : timerSet,1,5
3974 : Info : EVENT: BME280#Temperature=21.6
4637 : Info : Email: To ***@***.de
4799 : Info : EMAIL: Connection Closed Successfully
4810 : Info : EVENT: BME280#Humidity=35
4881 : Info : NTP : NTP replied: delay 20 mSec Accuracy increased by 0.555 seconds
4884 : Info : Time set to 1639305525.555 Time adjusted by 57817.31 msec. Wander: 0.000 msec/second Source: NTP
4887 : Info : Local time: 2021-12-12 11:38:45
4891 : Info : EVENT: Clock#Time=Sun,11:38
4935 : Info : EVENT: BME280#Pressure=1021
5010 : Info : EVENT: Time#Set
8952 : Info : EVENT: Rules#Timer=1,1
8986 : Info : ACT : DeepSleep,60
8988 : Info : EVENT: System#Sleep
9022 : Info : SLEEP: Powering down to deepsleep...
9024 : Info : WIFI : Set WiFi to OFF
Is there any event created that securely gives evidence that the notification task is closed and the Email is sent? Or any other ideas how to solve this smarter instead of simply delaying the deep sleep entry by 5s? My aim is to keep the uptime of the ESP as short as possible to elongate battery live time.
Posted: 12 Dec 2021, 12:52
by TD-er
A few things to keep in mind when testing this:
I do perform an ADC read right before trying to connect to WiFi, since the ADC reading is affected by WiFi RF calibration.
But this is also right at boot, so that may be a current surge and thus the first reading upto the moment WiFi is connected may report a lower value than later samples.
This can be exactly what you need, as a discharged battery also shows increased internal resistance and thus the voltage may drop more at higher currents.
So just to keep in mind when testing this.
Another thing you should really look into is the quiescent current of the parts that are permanently connected to the battery, like the voltage regulator.
Most regulators, like the AMS1117 do have a terrible high quiescent current of 5 - 10 mA.
Meaning the voltage regulator alone does draw this current even when the ESP is in deep sleep.
Just one source of information on this subject:
https://randomnerdtutorials.com/esp8266 ... batteries/
You can get away with LDO regulators which only can handle 200 mA, but then you may need to include a capacitor very close to the ESP of 22uF - 100uF.
But these may cause a high current when they are empty and need to be charged. For this you may need to add a R/C delay to the EN pin to delay starting the ESP until these caps are fully charged.
This may require some tweaking.
If you use sendtohttp, you may want to check "SendToHTTP wait for ack" on Tools->Advanced page to make sure the command is finished by the rules.
Posted: 12 Dec 2021, 14:49
by fm-maniac
I already checked "SendToHTTP wait for ack".
For the LVR I opted for a Torex XC6220 with a quiesent current of only 8µA (typ) if in PS-Mode (load current < 1mA). An MCP1700 is specified with even lesser 1,6µA but the XC6220 has a lower dropout voltage.
Finally it's the on period that discharges the battery...
I improved the rule by applying the timer only in case of an email has to be sent. Otherwise the deep sleep is entered imediatly:
event, CallDeepSleep
on Rules#Timer=1 do
on CallDeepSleep do
BTW: There's an GPIO readback to disable the deepsleep if pulled to GND by external jumper. For maintenance purposes.
