filtering of repeated signal?
Posted: 11 Nov 2021, 00:36
Hi! I'm using RFlink with Jeedom. I have an issue with fast repetion of the same remote signel. If the button is pushed twice in less than around 5 seconds, it seems the signal is ignored.
If I send 2 differents signals in repetion, I have a correct capture, even with a below 1 second which gives ABABABABABA.
But if I try to repeat the same signal AAAA,I need to leave few seconds between 2 pulses for them to be detected.
Is this a normal behaviour or is there something I can improve?
Thanks in advance!
Eric
Thanks in advance!
Eric
