I2C more than one device MCP23017
hello, i have problems with my version of espeasy on wroom32. I can only operate one device in I2C (mcp23017). Do you have an idea ? If I connect two mcp23017, the esp becomes very slow and or hangs. Thank you
Re: I2C more than one device MCP23017
What does the I2C scanner show?
How have you configured the I2C address of both MCP23017 modules (probably you changed jumpers), as they need to have different I2C addresses.
Most boards with I2C chips also have pull-up resistors on them.
If you add multiple boards to the I2C bus, it is possible the netto pull-up resistance becomes too low.
Do you have more I2C devices connected to the ESP?
If so, please check with only the MCP modules connected.
And of course look at the addresses as already suggested.
solved, I'm ashamed an area of my breabord was not powered ... pffff amateur Thanks to yu and have a nice weekend.
