Hihi,
I have set a rule that sends an email when the analog value is over 950 (heating on failure).
on LDR#Analog>950 do
notify 1, "Heizung auf Stoerung"
Now I want to change this so that it is only executed three times and then stopped until the analog value falls below 100 again.
Do you have any ideas about how I would have to change the rule?
Regards Franzel
Send a limited number of emails
Re: Send a limited number of emails
You can store the count in a variable.
And in the situation where you want to reset this counter, call "let,1,0"
let,1,[int#1]+1
if [int#1] < 3
Users browsing this forum: Google [Bot] and 1 guest
