Renkforce FT007TH
Posted: 22 Oct 2021, 10:34
by wimpie
Recently I bought Renkforce TF0073 weather station, which includes three TF007TH sensors, as this sensor is on the list of supported devices by RFLink release 48. The receiver is a kit purchased at the nodo-shop (URL https://www.nodo-shop.nl/nl/rflink-gate ... enne-.html) which is connected to a Raspberry Pi 3B. On the latter miniterm is used to read the serial output of RFLink. The periodic transmissions of a TF007TH sensor are not shown. However if '10;RFDEBUG=ON;' is entered, about once per minute a block of received pulses is shown. A typical example is:
20;0D;DEBUG;Pulses=294;Pulses(uSec)=390,390,390,420,390,420,360,420,390,390,390,390,390,390,390,420,390,420,360,870,870,870,870,870,420,360,420,360,870,870,870,420,390,870,870,870,420,360,900,870,870,870,420,360,420,360,870,870,870,900,420,360,420,360,420,360,870,390,390,870,870,390,390,390,390,870,420,360,870,420,390,420,390,870,420,360,870,870,420,360,870,420,390,870,870,390,390,390,390,870,420,360,420,390,420,360,900,390,390,390,390,390,390,390,390,420,390,390,390,420,390,420,390,420,390,420,390,870,900,870,900,870,420,390,420,390,870,870,870,390,390,870,870,870,420,360,870,870,870,870,420,360,420,360,900,870,870,870,420,360,420,360,420,360,870,390,390,870,870,390,390,390,390,870,420,390,870,420,390,390,390,870,420,360,870,870,420,360,870,420,390,870,870,420,360,390,390,870,420,390,420,360,420,360,870,390,390,390,390,390,390,420,390,420,390,420,390,420,390,420,390,390,390,390,390,870,870,870,900,870,420,360,420,360,870,870,870,390,390,870,870,870,420,390,870,870,870,870,420,360,420,360,870,870,870,870,420,360,420,360,420,360,870,390,390,870,870,420,390,390,390,870,420,360,900,420,360,420,390,870,420,360,870,870,420,360,870,420,390,870,900,390,390,390,390,870,420,360,420,360,420,390,450,6990;
Using one of the other two sensors does not change the behavior, but one message then consists of about 312 pulses.
A quick test with a klik-aan-klik-uit control unit did result in a decoded message:
20;16;NewKaku;ID=02240312;SWITCH=3;CMD=OFF;
What is needed to receive the decoded messages of the TF007TH sensors?
Re: Renkforce FT007TH
Posted: 09 Jan 2024, 02:23
by padrino
well TF007TH sensores seem quite unreliable here (with rflink) but they *do* work with rflink!
The problem (at least fir me) is that their signal sometimes is recognised right away and then for minutes, upto an hour or so, it is not.
And if the learning process falls into such a period, it's bad luck.
Unfortunately this behaviour does not change with recent V1.50 (hoped it would, as the changelog states that it fixed decoding problems... though I don't know of which kind they were 😅).
I also experienced that in debug mode the signal seems to be registered quite perfectly.
CU,
padrino
Posted: 24 Jan 2024, 16:41
by Stuntteam
Can you provide a debug log as shown here: https://www.rflink.nl/develop.php
But for step 3 activate only the logmode unhandled
That might help in improving things.
Posted: 25 Jan 2024, 16:07
by wimpie
The requested debug log is sent via a private e-mail.
Posted: 25 Jan 2024, 18:53
by padrino
Stuntteam wrote: ↑24 Jan 2024, 16:41 Can you provide a debug log as shown here: https://www.rflink.nl/develop.php
Would a "second pair" of data help in the process or are those of wimpie enough?
CU,
padrino
Posted: 25 Jan 2024, 19:09
by Stuntteam
Yes, always good to have a bit more to verify we can catch all packet types
Posted: 25 Jan 2024, 19:57
by padrino
Stuntteam wrote: ↑25 Jan 2024, 19:09 Yes, always good to have a bit more to verify we can catch all packet types
OK =)
Though hard to tell with all the neighbours and their 433mHz flodding, here is some data...
(possibly only the ones with 290 pulses really matter, but I tried to log every time both LEDs (sensor and arduino) flashed...
Here they are (or would you prefer email?):
16.2C
20;24;DEBUG;Pulses=290;Pulses(uSec)=570,90,630,240,510,270,510,270,510,270,510,300,480,300,480,300,480,300,480,780,990,780,990,780,480,300,480,300,960,810,960,330,450,330,450,330,450,810,480,300,480,300,930,810,450,330,450,330,930,810,450,330,450,330,930,360,420,840,930,360,420,360,420,840,450,330,930,360,420,840,930,840,930,360,420,840,900,840,930,360,420,840,420,360,900,390,390,390,390,390,390,840,420,360,450,330,450,330,900,390,390,390,420,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,900,870,900,870,420,360,420,360,900,870,870,390,390,420,390,390,390,870,420,390,420,390,870,870,420,360,420,360,870,870,390,390,390,390,870,420,360,870,870,420,360,420,360,900,390,390,870,420,360,900,870,900,870,390,390,900,870,900,870,420,360,900,390,390,870,420,360,420,360,420,360,900,390,390,390,390,390,390,870,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,900,870,900,870,900,390,390,390,390,870,900,870,420,360,420,360,420,360,900,390,390,390,390,870,900,390,390,390,390,870,900,390,390,390,390,870,420,360,900,870,420,360,420,360,900,390,390,840,420,360,900,870,900,870,420,360,900,870,900,870,420,360,900,390,390,870,420,360,420,360,420;
16.5C
20;16;DEBUG;Pulses=290;Pulses(uSec)=630,240,510,270,510,270,510,270,510,300,480,300,480,300,450,330,480,780,960,810,960,810,480,300,480,300,960,810,960,810,930,810,960,330,450,330,420,360,420,810,450,330,450,330,450,330,450,330,450,330,450,330,930,360,420,360,420,360,420,360,420,360,420,360,420,840,420,360,900,870,900,870,420,360,420,360,900,390,390,390,390,390,390,390,390,870,420,360,900,390,390,390,390,870,420,390,420,360,420,360,420,390,870,390,390,390,390,390,390,390,390,420,390,390,390,390,390,390,390,420,390,420,390,870,870,870,870,870,390,390,390,390,870,870,870,870,870,870,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,870,390,390,390,360,420,390,420,360,420,390,420,360,900,390,390,870,900,870,900,390,390,390,390,870,420,360,420,360,420,360,420,360,900,390,390,870,420,360,420,390,870,390,390,390,390,390,390,390,390,870,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,900,870,870,870,900,390,390,390,390,870,900,870,900,870,900,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,870,390,360,420,390,420,360,420,390,390,390,420,390,900,390,390,870,870,870,900,390,390,390,390,870,420;
20;09;DEBUG;Pulses=290;Pulses(uSec)=180,30,780,240,570,210,510,270,510,270,510,270,480,300,480,300,480,300,480,300,480,780,960,810,960,810,480,300,480,300,960,810,960,810,960,810,930,330,450,330,420,360,450,810,450,330,450,330,450,330,450,330,450,330,450,330,930,360,420,360,420,360,420,360,420,360,420,360,420,840,420,360,900,840,900,840,420,360,420,360,900,390,390,390,390,390,390,390,390,870,420,360,900,390,390,390,390,870,420,360,420,360,420,390,420,360,900,390,390,390,390,390,390,390,390,420,390,390,390,420,360,420,390,390,390,420,390,870,870,900,870,900,390,390,390,390,870,900,870,870,870,870,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,420,390,870,420,360,420,390,420,390,390,390,420,360,420,390,870,390,390,870,900,870,900,390,390,390,390,870,420,360,420,360,420,360,420,360,900,390,390,870,420,360,420,360,900,390,390,390,390,390,390,390,390,870,420,360,420,390,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,900,870,900,870,900,390,390,390,390,870,870,870,870,870,870,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,870,390,390,420,360,420,360,420,390,420,360,420,390,870,390,390,870,900,870,900,390,390;
20;0A;DEBUG;Pulses=60;Pulses(uSec)=360,2040,240,1860,360,420,390,3810,390,870,420,1830,420,870,360,900,420,1860,450,1800,420,1830,420,1830,390,870,420,840,420,840,420,840,420,870,420,900,360,840,420,870,420,810,450,1830,390,870,420,1830,390,930,360,1830,420,1830,420,1830,420,1860,360,1740;
20;0B;DEBUG;Pulses=32;Pulses(uSec)=30,60,450,840,420,870,420,840,420,840,420,870,420,870,420,1860,390,870,420,1830,420,840,420,1860,420,1830,420,1830,420,1830,420,1530;
16.6C
20;25;DEBUG;Pulses=105;Pulses(uSec)=210,1170,60,270,510,270,510,300,480,300,480,300,480,300,480,300,480,300,480,330,480,300,480,780,990,780,990,780,480,300,480,300,960,780,960,810,480,300,480,330,450,300,930,330,420,840,450,330,450,330,930,360,420,840,450,330,450,330,930,360,420,360,420,360,420,360,420,840,420,360,900,360,420,840,420,360,900,840,420,360,900,870,420,360,900,870,420,360,420,360,900,870,420,360,420,360,1290,390,480,300,480,300,480,300,1380;
20;26;DEBUG;Pulses=104;Pulses(uSec)=2280,420,450,330,450,330,450,330,510,270,360,420,360,420,360,420,360,420,360,900,870,900,870,900,390,390,390,390,870,900,870,900,870,900,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,870,420,360,420,360,420,360,420,360,420,360,420,360,900,870,420,360,900,870,900,390,390,870,900,390,390,390,390,870,900,870,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,420,6990;
16,9C
20;1D;DEBUG;Pulses=290;Pulses(uSec)=870,30,720,180,630,150,570,240,540,240,570,240,510,270,510,780,990,780,960,810,480,300,480,300,960,810,960,810,960,810,960,330,450,330,450,330,450,810,480,300,480,300,480,330,450,330,450,330,930,840,450,330,450,330,450,330,420,360,450,360,420,360,420,360,420,330,450,360,420,360,900,840,450,360,450,330,900,390,390,390,390,870,900,870,900,870,900,870,900,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,420,390,870,870,900,870,870,390,390,390,390,870,870,870,870,870,870,870,420,360,420,360,420,360,870,420,390,420,390,390,390,390,390,390,390,870,900,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,900,390,390,390,390,870,420,360,420,360,900,870,900,870,900,870,900,870,900,390,390,390,390,390,390,870,420,360,420,390,420,360,420,360,420,360,420,360,420,360,420,360,420,360,420,360,870,870,900,870,870,390,390,390,390,870,900,870,900,870,900,870,420,360,420,360,420,360,900,390,390,390,390,390,390,420,390,390,390,870,900,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,870,390,390,390,390,870,420,360,420,360,870,870,900,870,900;
20;0A;DEBUG;Pulses=290;Pulses(uSec)=630,150,660,210,480,300,480,300,450,330,480,810,960,780,960,810,480,300,480,300,960,810,960,780,960,810,930,330,450,330,450,330,450,840,450,330,450,330,450,330,450,330,450,330,930,840,450,330,450,330,450,330,450,330,450,330,450,330,450,360,930,840,450,330,900,840,450,360,420,360,900,390,390,390,390,390,390,390,390,870,900,870,420,360,900,390,390,870,420,360,420,360,420,360,900,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,870,870,870,870,390,360,390,390,870,870,870,870,870,870,870,420,360,420,360,420,360,900,390,390,390,390,420,390,420,390,390,390,870,870,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,900,390,390,870,900,390,390,390,390,870,420,360,420,360,420,360,420,390,900,870,900,390,390,870,420,390,900,390,390,390,390,390,390,870,420,360,420,360,420,360,420,390,420,360,420,360,420,360,420,360,420,360,420,390,900,870,900,870,900,390,390,390,390,870,870,870,900,870,900,870,420,360,420,360,420,360,870,390,390,420,360,390,390,390,390,390,390,870,900,390,390,390,390,390,390,390,390,390,390,390,390,390,390,870,870,390,390,870,870,390,390,420,390,870,420,360,420,360,420,360,420,390,900,870,870;
Posted: 26 Jan 2024, 00:22
by Stuntteam
It's ok :)
Posted: 05 Mar 2024, 21:08
by padrino
Stuntteam wrote: ↑26 Jan 2024, 00:22It's ok :)
Was the data usefull or do you need more?
I am eager to supply. :D
Posted: 06 Mar 2024, 11:28
by Stuntteam
data was ok, things are in progress.
