gfield
#1
Post
by gfield » 02 Oct 2021, 10:20
I have trouble with getting my ESP-8266 with ESP_Easy_mega_20210802_normal_ESP8266_4M1M to connect to my local WiFi. I have tried to make it connect both to my home WiFi as well as an AP created by my phone, but without success. In the case of my phone, I could see the unit for a brief moment (under connected devices in the phone's menu system) before the ESP-8266 unit apparantly disconnected.
The ESP-8266 comes from Plusivo kit (
https://www.plusivo.com/home/66-plusivo ... o-ide.html). Below I've posted output from the serial monitor. It looks like the unit is connected, but I can't reach it or ping it over the network.
INIT : Booting version: pygit2_not_installed (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
79 : Info : INIT : Free RAM:32264
81 : Info : INIT : Manual Reboot #10 Last Action before Reboot: Background Task Last systime: 665 - Restart Reason: External System
82 : Info : FS : Mounting...
107 : Info : FS : Mount successful, used 46686 bytes of 957314
128 : Info : CRC : SecuritySettings CRC ...OK
131 : Info : Time set to 665.000 Time adjusted by 664870.00 msec. Wander: 184.69 msec/second Source: RTC at boot
133 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
136 : Info : Local time: 1970-01-01 00:11:05
138 : Info : WiFi : Start network scan all channels
255 : Info : INIT : Free RAM:28192
257 : Info : INIT : I2C
257 : Info : INIT : SPI not enabled
366 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
372 : Info : Webserver: start
1718 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21976 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
2416 : Info : WiFi : Scan finished, found: 2
2419 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-65dBm) WPA2/PSK
2420 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-65dBm) WPA2/PSK attempt #0
2422 : Info : IP : Static IP : 192.168.1.123 GW: 192.168.1.1 SN: 255.255.255.0 DNS: 8.8.8.8
2428 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
3649 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 1222 ms
3650 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn.
3651 : Info : WIFI : Static IP: 192.168.1.123 (XXXX-ESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 6 ms
3743 : Info : firstLoopConnectionsEstablished
12135 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8389 ms
12136 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
12261 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 9832 ms
12263 : Info : WIFI : Static IP: 192.168.1.123 (XXXX-ESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 8 ms
20837 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8482 ms
20838 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
21739 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-65dBm) WPA2/PSK
21740 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-65dBm) WPA2/PSK attempt #1
21742 : Info : IP : Static IP : 192.168.1.123 GW: 192.168.1.1 SN: 255.255.255.0 DNS: 8.8.8.8
21888 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 145 ms
21889 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn.
21891 : Info : WIFI : Static IP: 192.168.1.123 (XXXX-ESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 3 ms
31708 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 20960 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
61708 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
61709 : Info : WiFi : Start network scan all channels
91708 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
121708 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
151708 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
151709 : Info : WiFi : Start network scan all channels
181708 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
211708 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
241708 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
241709 : Info : WiFi : Start network scan all channels
271707 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
301707 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 20456 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
331708 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 20664 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
331709 : Info : WiFi : Start network scan all channels
361708 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 20792 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
391707 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 20792 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
421708 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 20792 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
Post
by TD-er » 02 Oct 2021, 14:15
First you should disable the periodical scan for WiFi (I will remove the option as it is causing lots of issues.
And it seems like static IP may also be an issue here. Have to admit I have not tested static IP for a while. So will look into that part.
Can you first uncheck the periodical WiFi scan?
And if that's not working, can you try using DHCP?
gfield
#3
Post
by gfield » 02 Oct 2021, 15:49
How can I remove the periodical scan and the static IP address?
I have used ESP Easy Flasher to pre-configure the device via serial communication. I can't seem to remove the static IP adress through this tool. Unchecking static IP and then pressing "Program only" does not change the static IP. I am guessing that the tool assumes that the settings are "blank" and doesn't write anything at all when the checkbox is unchecked, i.e. it is impossible to remove the static IP address via this tool once it is set.
Is there some way to configure ESP-Easy via serial communication myself? Is the protocol documented somewhere?
(On a related note, I get readable serial output when monitoring using the serial monitoring program included in ESP Easy Flasher, but only jibberish when looking at the output from PuTTy. What is the baud rate? I'm using an ESP-8266 with a USB-TTCH340 chipset if that should matter...)
Post
by TD-er » 02 Oct 2021, 16:14
Baudrate is 115200.
See:
https://espeasy.readthedocs.io/en/lates ... l-commands
You can set the IP address via the command line (on the terminal connection via the serial port)
I have not tested it myself, but I guess setting it to an empty value may be used to set it back to DHCP:
or set it to 0.0.0.0:
Disabling periodical WiFi scan can only be done via the tools->advanced page (bottom page), but I can see that's a bit hard to do if the ESP does not seem to be reachable.
gfield
#5
Post
by gfield » 02 Oct 2021, 16:29
The disconnects seem to happen approximately every 8th second. Is this consistent with that the problem is periodical WiFi-scanning?
gfield
#6
Post
by gfield » 02 Oct 2021, 17:24
I seem to have the same issue as this:
viewtopic.php?t=7035
Things that I have tried:
- Flash first with blank_4M.bin and then re-flash with ESP_Easy_mega_20210802_normal_ESP8266_4M1M.bin
- Use an alternative WiFi network (Moto G8 Power mobile phone AP vs TP-LINK Archer MR200 router)
- Tried shorter WiFi password (14 symbols vs 30 symbols)
I did manage to connect to the ESP-Easy AP and reach the configuration page at one point when I did not set up any default networks, but it froze/stopped working after the page was loaded once. (I.e. I could not change any settings.)
I'm going to try ESP_Easy_mega_20210802_normal_
alt_wifi_ESP8266_4M1M.bin next...
Could this be a HW problem?
80 : Info : INIT : Manual Reboot #3 Last Action before Reboot: Background Task Last systime: 107 - Restart Reason: External System
107 : Info : FS : Mount successful, used 75802 bytes of 957314
129 : Info : CRC : SecuritySettings CRC ...OK
132 : Info : Time set to 107.000 Time adjusted by 106869.00 msec. Wander: 29.69 msec/second Source: RTC at boot
134 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
137 : Info : Local time: 1970-01-01 00:01:47
139 : Info : WiFi : Start network scan all channels
256 : Info : INIT : Free RAM:28224
258 : Info : INIT : I2C
259 : Info : INIT : SPI not enabled
368 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
375 : Info : Webserver: start
1721 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 21976 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
2419 : Info : WiFi : Scan finished, found: 2
2422 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
2423 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #0
2429 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
3534 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 1104 ms
3536 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
4085 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 552 ms
4088 : Info : firstLoopConnectionsEstablished
12590 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8960 ms
12591 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
13497 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
13498 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #1
13549 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 44 ms
14112 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 568 ms
14114 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
22625 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8981 ms
22626 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
24305 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
24306 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #2
24312 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
24486 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 163 ms
25024 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 552 ms
31711 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 20952 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
33583 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 9010 ms
33584 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
35263 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
35264 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #3
35270 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
35446 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 161 ms
35971 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 542 ms
44129 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8601 ms
44130 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
45039 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
45040 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #4
46218 : Info : WIFI : Disconnected! Reason: '(201) No AP found' Connected for 1125 ms
46320 : Info : WIFI : Set WiFi to OFF
46534 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
46536 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
46537 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #5
46641 : Info : WIFI : Set WiFi to STA
46763 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
46764 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #6
47884 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 1100 ms
47885 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
48413 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 546 ms
56928 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8962 ms
56929 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
57836 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
57837 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #7
58958 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 1106 ms
58959 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
59509 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 561 ms
61712 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 20952 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
61713 : Info : WiFi : Start network scan all channels
68090 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 9044 ms
68091 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
68998 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
69000 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #8
69182 : Info : WIFI : Disconnected! Reason: '(201) No AP found' Connected for 63 ms
69284 : Info : WIFI : Set WiFi to OFF
69498 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
69500 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
69501 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #9
69605 : Info : WIFI : Set WiFi to STA
69727 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
69728 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #10
71776 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 2047 ms
71778 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
72371 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 593 ms
80788 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 8911 ms
80789 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
81695 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
81696 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #11
83642 : Info : WIFI : Connected! AP: XXXX (98:DA:C4:24:23:DB) Ch: 1 Duration: 1939 ms
83644 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: Conn.
86101 : Info : WIFI : DHCP IP: 192.168.1.104 (XXXXESP8266-1) GW: 192.168.1.1 SN: 255.255.255.0 duration: 2462 ms
86102 : Info : WIFI : Arduino wifi status: WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP
91711 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 20952 WiFiStatus WL_CONNECTED 3 ESPeasy internal wifi status: Conn. IP Init
94509 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 10 s
94510 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
95417 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
95419 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #12
95601 : Info : WIFI : Disconnected! Reason: '(201) No AP found' Connected for 63 ms
95703 : Info : WIFI : Set WiFi to OFF
95917 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED 6 ESPeasy internal wifi status: DISCONNECTED
95919 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
95920 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #13
96024 : Info : WIFI : Set WiFi to STA
96146 : Info : WiFi : Best AP candidate: XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK
96147 : Info : WIFI : Connecting XXXX 98:DA:C4:24:23:DB Ch:1 (-73dBm) WPA2/PSK attempt #14
Post
by TD-er » 02 Oct 2021, 17:34
A hardware problem is not really likely.
I only found one module (black PCB, no shield over the ESP, looks like NodeMCU form factor) which does have really lots of problems with builds running core 2.5.x or newer (last 2 - 3 years).
Is your WiFi access point also using WiFi mesh?
Or is it an Asus access point?
gfield
#8
Post
by gfield » 02 Oct 2021, 17:53
Maybe it is a hardware problem.
What you are describing sounds like what I am working with.
I installed the alt_wifi version with no success. Then I stopped powering the unit via USB from my computer and connected it to a phone charger, and now got some more success. I managed to access the interface through the ESP Easy AP and configure the unit to access my home wi-fi. Now the unit shows up in the router menu as a connected unit, but I can't ping the unit... (Destination host unreachable.)
- IMG_20211002_174547724.jpg (4.17 MiB) Viewed 5114 times
Post
by TD-er » 02 Oct 2021, 18:24
You can try to hold your thumb over the PCB antenna.
It may even feel slightly warmer than the rest (not hot, no worries
) and by pressing the PCB antenna you may affect its tuning, which may help your unit to connect.
A build older than May 2019 (from the top of my head, could also be May 2018) may work though as those builds run core 2.4.0 or older.
#10
Post
by Ath » 02 Oct 2021, 18:36
It is quite unlikely that it would be related to fixed ip addresses, as *all* my units have a fixed ip address, and that is working fine here.
And also using a mesh system (TP Link Deco 9 plus, has the best coverage across my house) or the Netgear regular router as that's my secondary wifi setting. (Seeing the issues reported when using an Asus wifi mesh system, that's
not my next purchase
Post
by TD-er » 02 Oct 2021, 20:23
I don't have those Asus access points, but from what I've read about it online, it does look like it may be related to how the ESP does formulate its DHCP request and perhaps some timing issue or disconnect command issued by the mesh AP when it thinks another AP may be less utilized or according to the AP's may be more in range.
Anyway good to hear the static IP is not an issue.
Post
by TD-er » 02 Oct 2021, 20:25
gfield wrote: ↑02 Oct 2021, 17:53
Yep this PCB does look a lot like the one on my desk (sent to me by a user)
The one on my desk does show "Wemos" on the silkscreen on the antenna, but component layout is exactly the same.
Even the spots where there is no component but only solder pads.
