I am running a setup to count the revolutions of a ferraris disc to monitor my power usage. However I have a lot of problems with it.
I always count a lot less mAh than the meter.
I initially used the count to add up increments in my ioBroker setup but recently switched to using the total value and work with it because I believed it would be better to use it in case of connection loss.
However this did not fix the problem, I tried monitoring the total value in iobroker and noticed, that the total value is reset very often although I did not cut power or anything. Nor does it reach its maximum value.
I believed it only starts over when the maximum of the data type has been reacherd or the power has been cut.
Whats wrong here?
Kind regards
nils
Total Count always reseting
Users browsing this forum: Bing [Bot] and 35 guests
