ESP8266 release 20210802 starting problem
Posted: 09 Sep 2021, 23:21
by FanM
Hi there!
After flashing ESP_Easy_mega_20210802_normal_ESP8266_4M1M.bin i got next problem:
INIT : Booting version: pygit2_not_installed (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
80 : Info : INIT : Free RAM:32264
81 : Info : INIT : Manual Reboot #1 Last Action before Reboot: Background Task Last systime: 134 - Restart Reason: External System
83 : Info : FS : Mounting...
108 : Info : FS : Mount successful, used 75802 bytes of 957314
129 : Info : CRC : SecuritySettings CRC ...OK
133 : Info : Time set to 134.000 Time adjusted by 133868.00 msec. Wander: 37.19 msec/second Source: RTC at boot
135 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
137 : Info : Local time: 1970-01-01 00:02:14
140 : Info : WiFi : Start network scan all channels
256 : Info : INIT : Free RAM:28336
258 : Info : INIT : I2C
259 : Info : INIT : SPI not enabled
370 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
376 : Info : Webserver: start
1716 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 22064 WiFiStatus WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
2421 : Info : WiFi : Scan finished, found: 1
2423 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
3431 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
4434 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
5438 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
6442 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS 0 ESPeasy internal wifi status: DISCONNECTED
The same with 20210503 release.
The last working is 20210223
By the way, no matter if i burn bin from release or use VSCode for upload. The same result.
With ESP32 last release works fine, that problem only with ESP8266.
Re: ESP8266 release 20210802 starting problem
Posted: 09 Sep 2021, 23:26
Do you use an Asus access point?
And/or use WiFi mesh?
Posted: 10 Sep 2021, 00:01
by FanM
Yes, it is ASUS RT-N18U
No mesh, that is my basic router, it is connected directly to the internet.
Posted: 10 Sep 2021, 00:09
by FanM
By the way, about ESPEasy_ESP82xx_mega-20210223 release. Yes, it is working, but veeeery slow. Some pages can be opened after for 5-10 sec or do not open at all, need to realod page. And ping sometims just fall down.
Posted: 10 Sep 2021, 00:21
Slow WiFi response is something I also noticed on some APs when the ESP makes a reconnect.
Can you check the "Restart WiFi Lost Conn" optoin in the Tools->Advanced section?
There also seems to be a relation between "b/g" mode and "n" mode on those Asus units.
But there is something really wonky going on with Asus APs and the ESP modules (not only ESPEasy, also reports done by developers working on Tasmota and Espurna, which lately joined on some WiFI related topic I started regarding WiFi issues)
Posted: 10 Sep 2021, 10:49
by FanM
Seems it is not so simple.
1. About slow speed. I just connected ESP8266 (ESP_Easy_mega_20210223_normal_ESP8266_4M1M.bin) to another AP (that connected to my ASUS). Results:
ªU75 : Info :
INIT : Booting version: (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
76 : Info : INIT : Free RAM:34592
77 : Info : INIT : Warm boot #3 Last Action before Reboot: Const Interval: TIMER_20MSEC Last systime: 137 - Restart Reason: External System
78 : Info : FS : Mounting...
104 : Info : FS : Mount successful, used 75802 bytes of 957314
134 : Info : WIFI : Start network scan
2430 : Info : INIT : Free RAM:30472
2431 : Info : INIT : I2C
2431 : Info : INIT : SPI not enabled
2526 : Info : INFO : Plugins: 47 [Normal] (ESP82xx Core 2843a5ac, NONOS SDK 2.2.2-dev(38a443e), LWIP: 2.1.2 PUYA support)
2531 : Info : Webserver: start
2533 : Info : Time set to 137.000 Time adjusted by 134468.00 msec. Wander: 37.35 msec/second
2535 : Info : Current Time Zone: STD time start: 1970-10-25 03:00:00 offset: 0 min
2537 : Info : Local time: 1970-01-01 00:02:17
2553 : Info : WIFI : Scan finished, found: 4
2561 : Error : WIFI : No valid wifi settings
2561 : Info : WIFI : Set WiFi to AP+STA
3554 : Info : WIFI : AP Mode ssid will be ESP-Easy with address 192.168.4.1
3884 : Info : WD : Uptime 0 ConnectFailures 0 FreeMem 20736 WiFiStatus WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
4080 : Info : AP Mode: Client connected: 1C:BF:CE:43:03:8A Connected devices: 1
25537 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-27dBm) WPA/WPA2/PSK
25538 : Info : WIFI : Credentials Changed, retry connection. SSID: 3GWi-Fi_AB1C
25539 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-27dBm) WPA/WPA2/PSK attempt #0
25546 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
27740 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 2179 ms
27741 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
29834 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 2111 ms
29835 : Info : SaveToFile: free stack: 3552
29912 : Info : FILE : Saved config.dat
29912 : Info : SaveToFile: free stack after: 3552
29913 : Info : SaveToFile: free stack: 3552
29949 : Info : FILE : Saved security.dat
29949 : Info : SaveToFile: free stack after: 3552
29951 : Info : SaveToFile: free stack: 3216
29961 : Info : FILE : Saved security.dat
29962 : Info : SaveToFile: free stack after: 3216
29965 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
30022 : Info : firstLoopConnectionsEstablished
33874 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18512 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
44274 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 16 s
44275 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
44293 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
44649 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -42 status: STATION_CONNECTING
44662 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -42 status: STATION_CONNECTING
44675 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -42 status: STATION_CONNECTING
44688 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -42 status: STATION_CONNECTING
44701 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -42 status: STATION_CONNECTING
44715 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 19104 ms
44716 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
44717 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 64 ms
44718 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
49200 : Info : SaveToFile: free stack: 3360
49301 : Info : FILE : Saved config.dat
49302 : Info : SaveToFile: free stack after: 3360
49304 : Info : SaveToFile: free stack: 3024
49314 : Info : FILE : Saved security.dat
49314 : Info : SaveToFile: free stack after: 3024
59020 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
59021 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
59293 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -41 status: STATION_CONNECTING
59307 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -41 status: STATION_CONNECTING
59320 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -41 status: STATION_CONNECTING
59334 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -41 status: STATION_CONNECTING
59347 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -41 status: STATION_CONNECTING
59361 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1
59362 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
59363 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 69 ms
59364 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
63874 : Info : WD : Uptime 1 ConnectFailures 0 FreeMem 18600 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
73765 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
73766 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
75965 : Info : WIFI : Disconnected! Reason: '(201) No AP found' Connected for 16 s
75965 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
76392 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
76406 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
76418 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
76432 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
76445 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
76459 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1
76459 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
76461 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 70 ms
76462 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
90762 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
90763 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
91037 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
91050 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
91063 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
91076 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
91089 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
91105 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1
91105 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
91106 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 68 ms
91108 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
93876 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 18600 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
99861 : Info : AP Mode: Client disconnected: 1C:BF:CE:43:03:8A Connected devices: 0
99862 : Info : WIFI : Set WiFi to STA
114528 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 23 s
114529 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
115243 : Info : Reset WiFi.
115245 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
115359 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 1 m 55 s
115359 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
116349 : Info : WIFI : Set WiFi to STA
116453 : Info : WIFI : Start network scan
116454 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
118651 : Info : WIFI : Scan finished, found: 2
118653 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
118654 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
118661 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK attempt #0
118666 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
120268 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1590 ms
120269 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
120336 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 80 ms
120337 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
123877 : Info : WD : Uptime 2 ConnectFailures 0 FreeMem 22080 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
135019 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
135020 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
135930 : Info : WIFI : Start network scan
135932 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
138131 : Info : WIFI : Scan finished, found: 2
138132 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-25dBm) WPA/WPA2/PSK
138133 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-25dBm) WPA/WPA2/PSK
138140 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-25dBm) WPA/WPA2/PSK attempt #1
138145 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
138543 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 385 ms
138544 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
138646 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 117 ms
138648 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
153230 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
153231 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
153891 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 22464 WiFiStatus WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
154140 : Info : WIFI : Start network scan
154143 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
154244 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 15 s
154245 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
156347 : Info : WIFI : Scan finished, found: 3
156349 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
156350 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
156356 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK attempt #2
156362 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
158291 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1933 ms
158292 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
158394 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 99 ms
158395 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
172888 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
172889 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
173149 : Info : Reset WiFi.
173151 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -28 status: STATION_CONNECTING
173265 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 2 m 53 s
173266 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
174254 : Info : WIFI : Set WiFi to STA
174445 : Info : WIFI : Start network scan
174447 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
176648 : Info : WIFI : Scan finished, found: 3
176650 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-24dBm) WPA/WPA2/PSK
176651 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-24dBm) WPA/WPA2/PSK
176657 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-24dBm) WPA/WPA2/PSK attempt #3
176663 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
178321 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1654 ms
178322 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
178391 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 73 ms
178392 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
183873 : Info : WD : Uptime 3 ConnectFailures 0 FreeMem 16760 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
192754 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
192755 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
193342 : Info : Reset WiFi.
193345 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -26 status: STATION_CONNECTING
193458 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 3 m 13 s
193459 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
194450 : Info : WIFI : Set WiFi to STA
194607 : Info : WIFI : Start network scan
194609 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
196808 : Info : WIFI : Scan finished, found: 1
196814 : Info : WIFI : Start network scan
196816 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
199012 : Info : WIFI : Scan finished, found: 4
199014 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-19dBm) WPA/WPA2/PSK
199015 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-19dBm) WPA/WPA2/PSK
199022 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-19dBm) WPA/WPA2/PSK attempt #4
199027 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
200353 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1314 ms
200354 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
200407 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 64 ms
200408 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
213875 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 21168 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
214667 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
214668 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
215368 : Info : Reset WiFi.
215370 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
215484 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 3 m 35 s
215484 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
216476 : Info : WIFI : Set WiFi to STA
216633 : Info : WIFI : Start network scan
216635 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
218835 : Info : WIFI : Scan finished, found: 3
218836 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
218837 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
218844 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK attempt #5
218849 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
220374 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1514 ms
220374 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
220458 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 96 ms
220460 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
234942 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
234943 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
235384 : Info : Reset WiFi.
235386 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -24 status: STATION_CONNECTING
235500 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 3 m 55 s
235500 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
236491 : Info : WIFI : Set WiFi to STA
236648 : Info : WIFI : Start network scan
236650 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
238852 : Info : WIFI : Scan finished, found: 2
238854 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK
238855 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK
238861 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK attempt #6
238867 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
240393 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1529 ms
240394 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
240479 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 83 ms
240481 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
243875 : Info : WD : Uptime 4 ConnectFailures 0 FreeMem 19536 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
263827 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 23 s
263828 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
264412 : Info : Reset WiFi.
264415 : Info : WIFI : WiFiConnected() out of sync: DISCONNECTED RSSI: -25 status: STATION_CONNECTING
264528 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 4 m 24 s
264529 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
265518 : Info : WIFI : Set WiFi to STA
265709 : Info : WIFI : Start network scan
265711 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
267909 : Info : WIFI : Scan finished, found: 4
267911 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
267912 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK
267919 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-22dBm) WPA/WPA2/PSK attempt #7
267924 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
269448 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1514 ms
269449 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
269516 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 76 ms
269517 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
273873 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 21608 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
283684 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
283685 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
284595 : Info : WIFI : Start network scan
284597 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
286795 : Info : WIFI : Scan finished, found: 2
286797 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
286798 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
286804 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK attempt #8
286810 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
287260 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 441 ms
287261 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
287427 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 176 ms
287429 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
291951 : Info : Webserver args: 0: 'oldrulesengine' length: 2 1: 'ntphost' length: 0 2: 'dststartweek' length: 1 3: 'dststartdow' length: 1 4: 'dststartmonth' length: 1 5: 'dststarthour' length: 1 6: 'dstendweek' length: 1 7: 'dstenddow' length: 1 8: 'dstendmonth' length: 2 9: 'dstendhour' length: 1 10: 'timezone' length: 1 11: 'latitude' length: 8 12: 'longitude' length: 8 13: 'syslogip' length: 0 14: 'syslogport' length: 3 15: 'syslog_log_level' length: 1 16: 'syslogfacility' length: 1 17: 'serial_log_level' length: 1 18: 'web_log_level' length: 1 19: 'useserial' length: 2 20: 'baudrate' length: 6 21: 'udpport' length: 1 22: 'webport' length: 2 23: 'ip' length: 1 24: 'wdi2caddress' length: 1 25: 'wireclockstretchlimit' length: 1 26: 'cft' length: 1 27: 'restart_wifi_lost_conn' length: 2 28: 'max_wifi_tx_power' length: 5 29: 'wifi_sensitivity_margin' length: 1 30: 'edit' length: 1 31: 'plain' length: 466
291957 : Info : SaveToFile: free stack: 3328
292031 : Info : FILE : Saved config.dat
292032 : Info : SaveToFile: free stack after: 3328
292034 : Info : SaveToFile: free stack: 2992
292045 : Info : FILE : Saved security.dat
292046 : Info : SaveToFile: free stack after: 2992
303875 : Info : WD : Uptime 5 ConnectFailures 0 FreeMem 20920 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
314813 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 27 s
314916 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
315030 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 27 s
315132 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
315922 : Info : WIFI : Set WiFi to STA
316080 : Info : WIFI : Start network scan
316082 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
318278 : Info : WIFI : Scan finished, found: 1
318285 : Info : WIFI : Start network scan
318286 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
320493 : Info : WIFI : Scan finished, found: 3
320495 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK
320495 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK
320502 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-21dBm) WPA/WPA2/PSK attempt #9
320508 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
322470 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1964 ms
322471 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
322574 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 103 ms
322575 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
333874 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 20952 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
337145 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
337249 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
337362 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 14 s
337464 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
338253 : Info : WIFI : Set WiFi to STA
338411 : Info : WIFI : Start network scan
338413 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
340611 : Info : WIFI : Scan finished, found: 4
340612 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
340613 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
340620 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK attempt #10
340626 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
342482 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 1860 ms
342483 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
342568 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 84 ms
342569 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
357003 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
357106 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
357220 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 14 s
357322 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
358112 : Info : WIFI : Set WiFi to STA
358270 : Info : WIFI : Start network scan
358272 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
360469 : Info : WIFI : Scan finished, found: 3
360471 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
360472 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
360478 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK attempt #11
360484 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
362494 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 2000 ms
362495 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
362591 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 106 ms
362593 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
364058 : Info : WD : Uptime 6 ConnectFailures 0 FreeMem 18016 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
376663 : Info : WIFI : Disconnected! Reason: '(200) Beacon timeout' Connected for 14 s
376766 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
376880 : Info : WIFI : Disconnected! Reason: '(8) Assoc leave' Connected for 14 s
376981 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
377773 : Info : WIFI : Set WiFi to STA
377965 : Info : WIFI : Start network scan
377967 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
380166 : Info : WIFI : Scan finished, found: 1
380172 : Info : WIFI : Start network scan
380174 : Info : WIFI : Arduino wifi status: WL_IDLE_STATUS ESPeasy internal wifi status: DISCONNECTED
382382 : Info : WIFI : Scan finished, found: 2
382384 : Info : WIFI : Scan result: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
382385 : Info : WIFI : Selected: 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK
382392 : Info : WIFI : Connecting 3GWi-Fi_AB1C 00:67:65:46:AB:1C Ch:1 (-23dBm) WPA/WPA2/PSK attempt #12
382397 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: DISCONNECTED
384515 : Info : WIFI : Connected! AP: 3GWi-Fi_AB1C (00:67:65:46:AB:1C) Ch: 1 Duration: 2120 ms
384516 : Info : WIFI : Arduino wifi status: WL_DISCONNECTED ESPeasy internal wifi status: Conn.
384600 : Info : WIFI : DHCP IP: 192.168.169.100 (ESP-Easy) GW: 192.168.169.1 SN: 255.255.255.0 duration: 84 ms
384602 : Info : WIFI : Arduino wifi status: WL_CONNECTED ESPeasy internal wifi status: Conn.
393874 : Info : WD : Uptime 7 ConnectFailures 0 FreeMem 21040 WiFiStatus WL_CONNECTED ESPeasy internal wifi status: Conn. IP Init
It works better now. ANd i set the flag on Restart WiFi Lost Conn:. But anyway, please look at my logs. To many events, maybe something wrong...
2. About new firmware ESPEasy_ESP82xx_mega-20210802. Is is not about ASUS router. It happen right after firmware is flashed.Flash it and open serial and see that:
Posted: 10 Sep 2021, 11:01
by FanM
And want to add some info.
If compare with ESP32, anyway it works with delays. On ESP32 all pages open in 1 sec, if use ESP8266 it takes about 1-5 sec to open the page like
http://192.168.169.100/devices.
Sometimes it is not loading at all and need to reload the page.
Maybe it is Ok for ESP8266, i do not know, just tell me please.
Posted: 10 Sep 2021, 12:01
Nope it is not OK.
I have them running here and the load times of the pages hardly ever take a second to process.
Often it is between 150 - 300 msec to render a page.
But this depends on the client computer too.
For example if both the ESP and the PC you use to access the ESP are on the same WiFi network, you may see slower response.
Also on a slower PC (e.g. a laptop on batteries in power save mode) you will also see slower response, so it isn't as clear as "over xxx msec is too slow".
The ESP8266 (any ESP) should at least try to connect to an AP if it is connected, or start an AP to configure it.
How did you flash the ESP8266?
Using OTA? If so, can you please try to flash it using serial?
Especially the later builds, they seem to be acting strange on some boards when flashed via OTA.
Seems to be related to the brand of flash used.
Posted: 10 Sep 2021, 13:13
by FanM
Computer connected to ASUS router through the LAN.
ESP8266 connected to WiFi spot, that connected to ASUS by WiFi (without LAN, it is also connected with WiFi to ASUS)
Computer is powerful, not notebook.
I flash 2 ways
1. Using ESP.Easy.Flasher.exe and bin files that exist in the release
2. With VScode and Platformio. Compile sourсe and upload on the board. No defference. It means that i compile it correct
I am not programmer and not developer, just user with patience. Cannot stop till get the result.
I use that board in attach (please check).
Today will try some other moules. I have ESP-01 and one more, do not have a photo.
Posted: 10 Sep 2021, 15:19
by FanM
My first results. Tried to flash the last firmware ESP_Easy_mega_20210802_normal_ESP8266_4M1M.bin on another board.
Bingo!
It works. No delay, stable ping.
All the same, blank 4MB and flash with ESP.Easy.Flasher.exe.
Oh, so much time spent...
Something wrong with a board in last attach...
Posted: 10 Sep 2021, 16:12
by FanM
I checked 3 models more. ESP-01, ESP-12E and NodeMcu Lua WIFI V3. They all work perfectly.
SOLVED
All problems with that board that i attached before.
Thank you for supporting!
Posted: 10 Sep 2021, 16:52
Hmm that board image you showed...
I have one that's the same, sent by a user to me.
It is a problem with that specific board (or at least the batches using that board)
I have managed to get it to work on newer builds by pressing my thumbs hard on the antenna at a specific spot.
The strange thing is, on older builds (e.g. 2019 build) it worked upto a very specific build and then after that no newer build would work on that board.
The antenna also feels quite warm to the touch when trying.
I have also opened an issue for it on espressif/esp8266 to maybe allow for a wider range to compensate for badly tuned antennas.
The thing is, by pressing your fingers on the antenna you change the antenna's resonance frequency and then it suddenly starts to work. (and quick response too)
Posted: 10 Sep 2021, 17:16
by FanM
Wow, i am not the first one who stucked with such model.
I will try to touch antena on my modile, just for fun. But i am sure you are right about that.
The only thing i am trying to setup ESP8266 (not ESP32) only because of Blynk compatibility. Your colleague told me that only ESP8266 support it.
Posted: 10 Sep 2021, 18:04
I never tried Blynk.
And to be honest I don't know why it would not work on ESP32.
So need to try it to be sure
But trying a "NodeMCU" will probably work fine.
Posted: 10 Sep 2021, 19:00
by Ath
When I try to compile it into an ESP32 build, it throws an #error that it isn't compatible, the updated library version seems to resolve that, see
https://github.com/letscontrolit/ESPEasy/issues/3776 I just didn't get to update and PR it, yet.
