Domoticz MQTT Helper 0 then 1
Posted: 12 Jul 2021, 22:33
I've a switch input connected to dz with MQTT Helper like this I've found that the behavior is different when used from dz than from the hardware switch
From the switch, On then Off
From the dz, On then Off
There is 1 more event on Relay4, with the value opposite of the real ones
Which cause issue in my code because the code do the reverse to what I need!
ESP_Easy_mega_20210223_normal_ESP8285_1M
It is a "normal" behavior ?
If yes how could I do to trigger the good event?
272215: EVENT: Button4#State=0
272232: ACT : gpio,15,=!0
272235: GPIO : port#15: set to 1
272318: EVENT: Relay4#State=1
274514: EVENT: Button4#State=1
274532: ACT : gpio,15,=!1
274535: GPIO : port#15: set to 0
274622: EVENT: Relay4#State=0
274647: ACT : LogEntry,'*** Relay4=0'
274649: *** Relay4=0
285203: inputswitchstate is deprecatedinputSwitchState,7,1.00
285207: GPIO : port#15: set to 1
285229: EVENT: Relay4#State=0
285247: ACT : LogEntry,'*** Relay4=0'
285248: *** Relay4=0
285307: EVENT: Pump#Output=1
285409: EVENT: Relay4#State=1
288303: inputswitchstate is deprecatedinputSwitchState,7,0.00
288307: GPIO : port#15: set to 0
288326: EVENT: Relay4#State=1
288409: EVENT: Pump#Output=0
288507: EVENT: Relay4#State=0
288525: ACT : LogEntry,'*** Relay4=0'
288526: *** Relay4=0
