Power cycle-like ESP reset
mackowiakp
#1 Post by mackowiakp » 02 Jul 2021, 17:59
FW ESPEasy_ESP82xx_mega-20210503 custom compilation (Custom.h)
Is it possible to perform a reset of ESP in the way power cycle-like ?
The problem is that 3 devices are connected to one ESP via I2C. Very rarely - it happened probably 3-4 times a year - something "jammed" on the I2C bus and the devices connected there, although sending data, did not make sense.
For example, the BME280 showed a temperature of 2,000 C and a pressure of 2,000 HPa.
The reset from the power supply helped.
So my question. Is it possible to perform such a reset from rule, because the standard reboot command did not help to solve the situation.
Re: Power cycle-like ESP reset
#2 Post by Ath » 02 Jul 2021, 18:36
There is an open PR #3678 that is intended to resolve such situation of a blocked I2C bus, that could use some real life testing, I presume. You could get a build from the Github Actions page, and see if that resolves your issue.
mackowiakp
#3 Post by mackowiakp » 02 Jul 2021, 18:45
OK. I will try. But as I wrote, it happens very rarely, so I don't know when I will be able to write something about the results.
But such a "reset" as from power cycle would be useful ....
#4 Post by Ath » 02 Jul 2021, 18:55
The trick to get that working would be a relay with a short timer, that can be triggered to off by the ESP, and would restore power in a couple of seconds (10..20), after which the issue would be solved as well, but I'd prefer a software-controlled solution, and possibly a fix in the Arduino base libraries, as it seems that's where the root-cause possibly is.
mackowiakp
#5 Post by mackowiakp » 02 Jul 2021, 19:49
Yes, using for example 4541 based timer + relay or transistor resolve the problem. But it is additional hardware, soldering etc.
I just looking for simpler way that is via software (forcing hardware watchdog reset or so).
#6 Post by TD-er » 02 Jul 2021, 21:29
You can temporarily swap the SDA and SCL pins (in the settings) and restore them after saving it.
This will also clear the blocked I2C bus.
Still not a very nice fix, but at least it helps for those units at unreachable places.
#7 Post by ThomasB » 02 Jul 2021, 23:29
A Relay might not be needed for this solution. Perhaps it can be simplified by connecting the ESP device's reset pin to a spare GPIO pin (any GPIO that is not used for Boot mode or serial port). Leave the GPIO configured as default in hardware settings. Use a rule event to set the pin logic low (GPIO,<gpio>,0) whenever the hard reset is needed.
For example, connect GPIO14 (D5) to RST.
Use web browser to call the HardReset Event. Use this rule:
on HardReset do
     gpio,14,0
Or maybe a rule could be created that automatically checks for a hung I2C. For example, periodically read the state of the SCL pin. If it is stuck at a logic low then call the HardReset event.
Untested ideas, offered for your amusement only.
mackowiakp
#8 Post by mackowiakp » 03 Jul 2021, 01:08
Yep, good idea. Will test !
mackowiakp
#9 Post by mackowiakp » 03 Jul 2021, 02:26
After quick test on prototype ESP, I can say it works. But the problem is with desired device.
All GPIOs that do not change state during boot are busy and unfortunately must remain so.
But the D5 changes state for each minutes, resetting/force "sleep" the dust sensor. Dust sensor has a very limited LED lifetime (8,000 hours), so I turn it on every 10 minutes for 30 seconds, measure air quality and then it does to "sleep" again.
So I can only use this fact, modify the rule accordingly and connect a simple 4541 based timer to D5 + transistor. If there is no reset 4541 from D5 for 11 minutes, the transistor will reset the ESP.
I use a similar solution in RPi, where the hangs of the system as a whole is not a result of a software error or RPi itself, but a temporary malfunction of one of the peripheral devices. For example, due to a lightning strike.
So still power cycle-like reset would be much easier to do....
#10 Post by ThomasB » 03 Jul 2021, 03:22
That is unfortunate that a spare GPIO is unavailable.
However, do you have anything wired to the GPIO-2 (D3) boot pin? If it is free then I have an idea.
mackowiakp
#11 Post by mackowiakp » 03 Jul 2021, 03:30
Dont know at this moment. Probably no. I have to check during a day (at this moment is 3:30 AM in my country).
The unit is located 20 m from my house.
Your idea sounds good. Will test ASAP.
#12 Post by ThomasB » 03 Jul 2021, 03:39
I just tried out my GPIO-2 workaround idea. It won't work. So for now I am out of easy-to-implement ideas.
Hopefully the firmware solution in PR #3678 solves this for you.
mackowiakp
#13 Post by mackowiakp » 03 Jul 2021, 03:46
So external hardware timer/watchdog seams to be solution for actual and future problems.
Lets solder 15 cents worth IC to external board. :D
mackowiakp
#14 Post by mackowiakp » 03 Jul 2021, 03:51
Wait, I have GPIO5 (D1) free ! Be so kind to test. Its totally independent input/output !
#15 Post by ThomasB » 03 Jul 2021, 04:26
Are you sure GPIO-5 is free? Normally it is used for I2C SCL.
If this pin is indeed free then give it a try. Be sure to check the device's /hardware page and confirm that GPIO5's "GPIO boot states" is set to default. No other entries should specify GPIO-5.
mackowiakp
#16 Post by mackowiakp » 03 Jul 2021, 04:32
Yes, its free for sure. In my case I2C use GPIO2 (SCL) and GPIO4 (SDA). I made a lot of changes/tests during the lifetime of this particular unit and some things are in non-default place.
#17 Post by ThomasB » 03 Jul 2021, 19:40
FWIW, I tried GPIO-5 and it works for me (remote reboot success). So hopefully this simple GPIO based hardware reset idea solves your problem.
mackowiakp
#18 Post by mackowiakp » 03 Jul 2021, 19:59
Yep, for me working too. Using additional transistor to inverse signal level.
#19 Post by ThomasB » 03 Jul 2021, 20:26
Great. Glad it's working.
I simply jumped GPIO-5 to RST with a piece of wire. The transistor seems redundant. But I suppose you prefer writing GPIO,5,1 instead of GPIO,5,0.
mackowiakp
#20 Post by mackowiakp » 04 Jul 2021, 07:28
All you need was a cable? Not in my case. GPIO5 shorted to GND at boot time for a fraction of a second, causing boot-loop.
Hence, I had to use an intermediate transistor.
You see "Chinese copy of the Chinese copy" of nodeMCU does not equal other "Chinese copy of the Chinese copy"
Anyway, this is not the first time I have encountered something like this.
#21 Post by TD-er » 04 Jul 2021, 10:29
Shorting GPIO-5 to GND may draw too much current from the ESP if it was high.
ThomasB did mention to connect GPIO-5 to RST.
mackowiakp
#22 Post by mackowiakp » 04 Jul 2021, 10:52
My part of ESP shorts GPIO5 to GND itself during boot time (for a fraction of sec). Why? I really dont know. It should not.
I just connected transistor to GPIO5 via resistor and transistor shorts RST to GND when command GPIO,5,1.
That's just for the more precise explanation.
#23 Post by TD-er » 04 Jul 2021, 11:08
Hmm that's strange.
GPIO-5 should be "safe to use for relays" .
See also the links I put on this page: https://espeasy.readthedocs.io/en/lates ... on-esp8266
mackowiakp
#24 Post by mackowiakp » 04 Jul 2021, 11:24
Yes, its strange but its a feature of my one personal ESP. I check another one, works as docu stands. "Chinese copy of Chinise copy..."
mackowiakp
#25 Post by mackowiakp » 26 Jul 2021, 05:47
Today the device hanged itself for the first time. As a result, the GPIO rule-initiated hard-reset did not work.
I know for sure that there was a hanging, because the simple rule "LED blinking" did not work. The LED was on all the time, not blinking.
The power cycle helped.
So I will have to use an additional external hardware watchdog based on timer 4541.
If the timer is not reset, let's say - for 5 minutes, it will turn off for a while (via relay) the power to everything (including timer 4541) .
