ESPEasy-NOW
Posted: 03 Jun 2021, 16:28
Hello.
I searched here at the forum and at GitHub looking for the actual status of ESPEasy-NOW but can't find a clear answer (only some references on the change log about some fixes with the merge process).
I have some questions regarding the status and implementation for ESP-Now in ESP Easy.
Is ESPEasy-NOW usable now?
Is compatible with other ESP8266 and ESP32 devices using the standard Espressif's ESP-Now implementation (not using ESP Easy)?
Is posible to use ESPEasy-NOW at the same time as wifi (to choose to use one, the other or both)?
Is possible to turn it off (and on) for battery powered devices (I think with the actual wifi implementation is not possible to do it, something like modem sleep)?
Yes, I know there are many questions but I already have an CO2 monitor based on ESP Easy with some hundred users that already build it (link at my signature, sorry automatic translation to English, only) and I'm very close to launch a ultra low CO2 monitor using ESP-Now (no ESP Easy based) and would like to know because this can change my plans (it's here if you want to see it (with half way manual English translation): https://emariete.com/diseno-medidor-co2 ... o-consumo/, a DIY Ultra Low Power Consumption CO2 Monitor) .
Thank you very much.
Mario
Mario
