Hello from Luebeck
Posted: 16 Apr 2021, 10:58
Hello to the community,
first of all I want to say thank you very much for this very interesting forum!
I want to use some ESP boards in my ioBroker system. So I found the possibility to use ESP-Easy on the ESP-boards. I try to understand how all works, but there are still many things I have to learn . One system ist running (thanks to TD-er). Is here around Luebeck someone interested to work together and to change information about using the ESP-Easy flashed esp boards? I have some projects to check the water level, the flow rate, the CO2 concentration, the particulate matter. I will realize them one by one.
Hope that I will get here more details to connect my sensors to the esp8266 boards in the right way .
Best regards!
Best regards!
