RFlink wemos gateway
Posted: 11 Apr 2021, 01:18
I wanted to have a bridge between my rflink and my openHab server.
So I have connected my RFlink to a wemos.
The wemos read serial from rflink and send it to mqtt server.
You can link sensors to wemos interactively.
espeasy firmware is free and rflink too, so i share my work too.
This is an arduino ide file.
( I Know this is not state of the art coding ! )
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <PubSubClient.h>
#include <string.h>
#include <EEPROM.h>;
#define RESET_EEPROM false
const char* ssid = "WifiSSID"; // SSID
const char* password = "wifipass"; // Password
#define mqtt_server "server"
WiFiClient espClientRFLINK;
PubSubClient mqttclient(espClientRFLINK);
SoftwareSerial SoftSer(D1,D2);
char temp[6];
byte idx = 0;
int i=0;
byte id_capteur=0;
int temperature=0;
int humidite=0;
int EtatBatterie=0;
char root_topic[16]="RFLINK/capteur0";
char topic[50];
char inData[80];
typedef struct {
char marque[20];
char ID[20];
} capteurs;
capteurs capteur[10];
void EEPROMcommit()
if (EEPROM.commit()) {
Serial.println("Data successfully committed");
} else {
Serial.println("ERROR! Data commit failed");
void GestionEEPROM()
Serial.println(EEPROM.read(0));
Serial.println(EEPROM.read(1));
if ( (EEPROM.read(0)!=0xAA) || (EEPROM.read(1)!=0xAA) )
{// premier démarrage, on efface l'eeprom et on marque les deux premier bytes en AA
Serial.println("Premier démarrage, effacement de l'eeprom");
EEPROM.write(0,0xAA);
EEPROM.write(1,0xAA);
for (int i=2;i<512;i++)
EEPROM.write(i,0);
EEPROMcommit();
else // ce n'est pas le premier démarrage, on recharge la liste des capteurs associés
LireListeCapteurs();
ListerLesCapteurs();
void LireListeCapteurs()
for (int i=0;i<10;i++)
for(int j=0;j<20;j++)
capteur[i].marque[j]=char(EEPROM.read(2+i*40+j));
capteur[i].ID[j]=char(EEPROM.read(2+i*40+j+20));
void EnregistrerListeCapteurs(){
for (int j=0;j<20;j++)
EEPROM.write(2+i*40+j,capteur[i].marque[j]);
EEPROM.write(2+i*40+j+20,capteur[i].ID[j]);
EEPROMcommit();
void ListerLesCapteurs(){
Serial.print("Capteur ");
Serial.print(i);
Serial.print(" :");
Serial.print(capteur[i].marque);
Serial.print(":");
Serial.println(capteur[i].ID);
void InitCapteurs()
capteur[i].marque[j]=0;
capteur[i].ID[j]=0;
void setup() {
Serial.begin(57600);
SoftSer.begin(57600);
delay(1000);
Serial.println("INIT Serial OK");
EEPROM.begin(512);
delay(3000);
InitCapteurs();
GestionEEPROM();
WiFi.begin(ssid, password);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
Serial.println(WiFi.localIP());
mqttclient.setServer(mqtt_server, 1883);
initCode();
void reconnect() {
// Loop until we're reconnected
while (!mqttclient.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
// If you do not want to use a username and password, change next line to
// if (client.connect("ESP8266Client")) {
if (mqttclient.connect("ESP8266ClientRFLINK")) {
Serial.println("connected");
} else {
Serial.print("failed, rc=");
Serial.print(mqttclient.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
char reception[80];
const char * separators = ";";
String code[8];
uint8_t indexcode=0;
void initCode(){
for (int i=0;i<8;i++)
code[i]="";
void printCode(){
for (int i=0;i<8;i++){
Serial.print(i);
Serial.print(":");
Serial.print(code[i]);
Serial.print(":");
Serial.println(":");
boolean ecoute(int duree){
long temps=millis();
boolean EnCours=false;
boolean recu=false;
idx=0;
indexcode=0;
for (int i=0;i<80;i++)
inData[i]=NULL;
while( (millis()-temps<duree) && (recu==false) )
if (EnCours==true)
temps=millis();
EnCours=false;
while(SoftSer.available() > 0)
EnCours=true;
char aChar = SoftSer.read();
if( aChar =='\n' )
char * strToken = strtok(inData,separators);
while ( strToken != NULL )
// Serial.print(":");
// Serial.print(strToken);
code[indexcode++]=strToken;
// Serial.println(":");
strToken = strtok(NULL,separators);
idx = 0;
inData[i]=NULL;
//printCode();
recu=true;
inData[idx] = aChar;
idx++;
//inData[idx] = '\n'; // Keep the string NULL terminated
indexcode=0;
//Serial.print("recu:");
//Serial.println(indexcode);
if (indexcode!=8) recu=false; // si on ne reçoit pas le nombre de parametre attendu on ignore
return recu;
char AttenteReponse(int duree){
char temp=0;
while (millis()-temps<duree)
if (Serial.available()>0)
temp=Serial.read();
while (Serial.available()>0) Serial.read();
return temp;
return 0;
void verification()
boolean match=false;
if (code[3]==capteur[i].ID)
Serial.print("Match : ");
match=true;
char temp[6];
temp[0]='0';
temp[1]='x';
for (int i=2;i<6;i++)
temp[i]=code[4][i+4];
temp[6]='\0';
temperature=strtol(temp,NULL,16);
if (temperature>0x7FFF)
//Serial.println("Negatif");
temperature-=0x7FFF;
temperature*=-1;
Serial.println(i);
root_topic[14]=i+48;
strcpy(topic,root_topic);
strcat(topic,"/temperature");
Serial.print(topic);
Serial.print(":");
Serial.println(String(temperature/10.0).c_str());
mqttclient.publish(topic, String(temperature/10.0).c_str(), true);
//topic[0]='\n';
temp[0]=code[5][4];
temp[1]=code[5][5];
temp[2]='\0';
humidite=atoi(temp);
strcat(topic,"/humidite");
Serial.print(":");
Serial.println(String(humidite).c_str());
mqttclient.publish(topic, String(humidite).c_str(), true);
// for (int j=0;j<sizeof(code[2]
if (match==false)
Serial.print("Capteur non associé : ");
printCode();
void loop() {
if (!mqttclient.connected()) {
reconnect();
mqttclient.loop();
if (ecoute(1000)==true)
//printCode();
verification();
//else Serial.println("Timeout");
char rep=AttenteReponse(1000);
if (rep=='c')
if (rep=='l')
if (rep=='e')
Serial.println("Etes vous sur de vouloir supprimer les capteurs associés ? o/n");
if (AttenteReponse(3000)=='o')
EEPROM.write(i,0);
EEPROMcommit();
if (rep=='a')//if (Serial.read()=='a')
//Serial.flush();
Serial.println("Association");
Serial.println("Appuyez sur le bouton ou enlever et remettre la pile");
Serial.println("Attente du signal");
if (ecoute(10000)==true)
Serial.println("Code reçu");
printCode();
Serial.println("Ajouter ? o/n");
if (AttenteReponse(10000)=='o')
//TODO ajout
Serial.println("Liste des capteurs associés :");
Serial.println("Choisir le numéro :");
//int NumeroCapteur=0;
while(Serial.available()>0) Serial.read();
int NumeroCapteur=AttenteReponse(10000);
if ((isDigit(NumeroCapteur))==true)
for (int i=0;i<sizeof(code[2]);i++)
capteur[NumeroCapteur-48].marque[i]=code[2][i];
for (int i=0;i<sizeof(code[3]);i++)
capteur[NumeroCapteur-48].ID[i]=code[3][i];
EnregistrerListeCapteurs();
Serial.println("Vous n'avez pas saisi un numéro, sortie du mode association");
//Serial.flush();
Serial.println("Sortie du mode association");
Serial.println("pas de code recu, sortie du mode association");
