Change Sensor value
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
Lonzo
Change Sensor value
#1 Post by Lonzo » 10 Apr 2021, 17:37
Hi, I have a small problem: I am measuring waterpressure, value goes in ADS0#Wasserdruck. Works fine - but: if no water is flowing the values swings around 0 (-0.1, 0,04 and so on).
Is ist possible to create a rule like: if ADS0#Wasserdruck<0.2 then sensor value is 0.00?
Under ESPeasy it is easy to use an internal variable, but in RPIEasy I don´t know how to do.
Maybe someone can help me.
Thank you
Lonzo
enesbcs
Re: Change Sensor value
#2 Post by enesbcs » 11 Apr 2021, 18:20
Lonzo wrote: 10 Apr 2021, 17:37 Hi, I have a small problem: I am measuring waterpressure, value goes in ADS0#Wasserdruck. Works fine - but: if no water is flowing the values swings around 0 (-0.1, 0,04 and so on).
There are a lot of possibilities. I guess you are using an Analog ADS1115 device. You can either set decimals to zero, or use a simple formula at the plugin page to smoothen values. For example:
max(int((%value% * 10) / 10),0)
Lonzo
#3 Post by Lonzo » 12 Apr 2021, 12:08
Tank you! I will test it.
