GPIO pin state monitoring
Affinite
#1 Post by Affinite » 21 Feb 2021, 21:13
I have a Relay connected to GPIO5 (so Im using GPIO5 as an output)
I turn it on/off using command GPIO,5,1/0 over MQTT
Rather than assume that the MQTT message has been received and actioned, I'd also like the to read the status of GPIO5 and have it reported back over MQTT
but I cant find a way to make work.
I'm new to rules but I can create a rule which monitors the status of a input switch device on the pin(5) but not if the pin state has been changed by a command
Any pointers gratefully received.
PS Sorry if this is covered elsewhere but I cant find my answer in here or in wiki.
Re: GPIO pin state monitoring
#2 Post by TD-er » 21 Feb 2021, 21:19
The "monitor" command should handle this as it is polling the monitored pins multiple times a second.
In this (pending) pull request there is also some long overdue documentation for the GPIO commands: https://github.com/letscontrolit/ESPEasy/pull/3431
Affinite
#3 Post by Affinite » 21 Feb 2021, 23:23
Thanks, I'll take a look tomorrow.
I had been using monitor but perhaps incorrectly.
Update:
Dont know what I was doing wrong yesterday but today "monitor" works just fine for me.
Sorry to waste your time :oops:
Rules attached for the benefit of other Rules newbies like me.
on System#Boot do
   Monitor gpio,4
   Monitor gpio,5
   Monitor gpio,15
On gpio#4=1 do
   Publish,MYESP/electrical.chargers.thruster,ON
On gpio#4=0 do
   Publish,MYESP/electrical.chargers.thruster,OFF
On gpio#5=1 do
   Publish,MYESP/electrical.chargers.start,ON
on gpio#5=0 do
  Publish,MYESP/electrical.chargers.start,OFF
On gpio#13=1 do
   Publish,MYESP/electrical.chargers.solar,ON
On gpio#13=0 do
   Publish,MYESP/electrical.chargers.solar,OFF
GravityRZ
#4 Post by GravityRZ » 01 Mar 2021, 17:27
a workaround is to set avariable each time a gpio changes
On gpio#4=1 do
   let,4,1
then you can check or send it out with
if [VAR#4]=1
or publish .... [VAR#4]
kimot
#5 Post by kimot » 04 Mar 2021, 21:31
The good old method still works:
( ESP_Easy_mega_20201227_minimal_core_274_ESP8285_1M_OTA_Domoticz )
code example from my code for relay toggle ( and report actual state to Domoticz ):
on change  do
  if  [Relay#State]=0
    gpio,12,1
    SendToHTTP 192.168.1.253,8080,/json.htm?type=command&param=switchlight&idx=163&switchcmd=On
    gpio,12,0
    SendToHTTP 192.168.1.253,8080,/json.htm?type=command&param=switchlight&idx=163&switchcmd=Off
GravityRZ
#6 Post by GravityRZ » 14 Mar 2021, 12:47
question regarding monitoring GPIO.
When monitored it is checking the status several times a second.
does this also mean that when you have someting like
On GPIO#12=0 do
this is also called serveral times a second or only once it changes from 1 to 0
if it does this means monitoring GPIO increases the workload a lot
#7 Post by TD-er » 14 Mar 2021, 13:15
Yep, the monitoring is potentially a real resource hog.
I am not really sure yet what to do to help this out a bit as it does fire an event, which gets processed in the rules.
Rules processing is already taking quite a hit on performance if done at a higher rate.
See also https://espeasy.readthedocs.io/en/lates ... tem-events
on System#Boot do
 Monitor GPIO,15
 on GPIO#15=0 do
  if [Plugin#GPIO#Pinstate#13]=0
   // do something
 on GPIO#15=1 do
  if [Plugin#GPIO#Pinstate#13]=1
   // do something
I can give a few tips to make rules processing less of an issue.
- Place the most frequently called events on top of the first rules file
- Try matching on %eventvalueN% in the event handler block and not too specific on...do specifiers.
GravityRZ
#8 Post by GravityRZ » 14 Mar 2021, 13:55
thanks.
good to know that this is causin extra load which can be avoided
normally i use the eventhandler but for testing purposes i use GPIO monitoring.
When i am done testing i will switch back
