Matrix Display with movement detector for custom message
Grumpf
#1 Post by Grumpf » 09 Feb 2021, 17:27
CURL or Espeasy + Serial server ?
I'm using the example in the MD_MAX72XX for Esp8266 to display a custom message to a 128X8 SPI matrix display. The code works and I slightly modified it with a timer and a movement detector (RCWL0516) so the leds will be off when noone is watching (to prevent light pollution).
So far, the example is about filling a field on the Esp webpage and clicking the button :
const char WebPage[] =
"<!DOCTYPE html>" \
"<html>" \
"<head>" \
"<title>MajicDesigns Test Page</title>" \
"<script>" \
"strLine = \"\";" \
"function SendText()" \
"  nocache = \"/&nocache=\" + Math.random() * 1000000;" \
"  var request = new XMLHttpRequest();" \
"  strLine = \"&MSG=\" + document.getElementById(\"txt_form\").Message.value;" \
"  request.open(\"GET\", strLine + nocache, false);" \
"  request.send(null);" \
"</script>" \
"</head>" \
"<body>" \
"<p><b>MD_MAX72xx set message</b></p>" \
"<form id=\"txt_form\" name=\"frmText\">" \
"<label>Msg:<input type=\"text\" name=\"Message\" maxlength=\"255\"></label><br><br>" \
"</form>" \
"<br>" \
"<input type=\"submit\" value=\"Send Text\" onclick=\"SendText()\">" \
"</body>" \
"</html>";
This works fine but I want to send the message through my home automation system (Domoticz).
I have done that in the past using the serial server plugin & an arduino to display on a TFT. It works but it's cumbersome. I guess I can do it again, hook an arduino to the Display and link it with serial to an Esp module.
-- ~/domoticz/scripts/lua/script_device_SerialOut.lua
-- Slave Arduino Uno with TFT will expect 19200 Bps (check Arduino code and Serial server on Wemos
-- $ to reset text style %24 and # to increase style by 1 %23
-- So for text in style n°4 string should start with $### = Reset to 1 +1 +1 +1 so 4
-- Script parameters
Debug = "Yes"                    -- Turn debugging on ("YES") or off ("NO")
local SERSTR
local PRESERSTR
-- Script functions
function Serout() -- Output the message to Wemos Serial
	if Debug=="Yes" then
		print ("Six : " .. SERSTR)
	end
		SERSTR = "http://172.19.0.206/control?cmd=serialsend," .. PRESERSTR .. os.date("%X") .. "%20" .. SERSTR
		os.execute('curl -s ' ..SERSTR)
end
-- CommandArray
commandArray = {}
 if (devicechanged['Security-Hall Door'] == 'Alarm') then
		SERSTR = "Hall%20open"
		PRESERSTR = "%24%23%23"
 elseif (devicechanged['Security-Hall Door'] == 'Normal') then
        SERSTR = "Hall%20Close"
		PRESERSTR = "%24%23"
 elseif (devicechanged['Security-Kitchen door'] == 'Alarm') then
		SERSTR = "Kitchen%20open"
 elseif (devicechanged['Security-Kitchen door'] == 'Normal') then
        SERSTR = "Kitchen%20Close"
 elseif (devicechanged['Security-Fitness Room'] == 'Alarm') then
		SERSTR = "Fitness%20open"
 elseif (devicechanged['Security-Fitness Room'] == 'Normal') then
        SERSTR = "Fitness%20Close"
----------------------------------------NO DEVICE ---------------------------------------------
 --elseif (devicechanged['Bedroom window'] == 'Alarm') then
--		SERSTR = "Bedroom%20open"
--		PRESERSTR = "%24%23%23"
-- elseif (devicechanged['Bedroom window'] == 'Normal') then
--        SERSTR = "Bedroom%20Close"
--		PRESERSTR = "%24%23"
-- elseif (devicechanged['Pantry window'] == 'Alarm') then
--		SERSTR = "Pantry%20open"
-- elseif (devicechanged['Pantry window'] == 'Normal') then
--        SERSTR = "Pantry%20Close"
 elseif (devicechanged['Security-Motion Salon'] == 'Motion') then
		SERSTR = "Salon%20motion"
		PRESERSTR = "%24%23%23%23"
 elseif (devicechanged['Security-Motion Hall'] == 'Motion') then
        SERSTR = "Hall%20Motion"
 elseif (devicechanged['Security-Motion Office'] == 'Motion') then
        SERSTR = "Office%20Motion"
 elseif (devicechanged['Lantern Switch'] == 'On') then
        SERSTR = "Lantern%20On"
		PRESERSTR = "%24%23%23%23%23"
 elseif (devicechanged['Lantern Switch'] == 'Off') then
        SERSTR = "Lantern%20Off"
 else -- Script will stupidely run for every device change so you need this
	return commandArray
end
Serout()
return commandArray
  ///     This is the program for the "slave" Arduino TFT                    ///
  /// Solder the 4 pins of the "serial connector" of the  Uno to a 90° right ///
  /// angle connector. This way you'll be able to connect a cable and place  ///
  /// the TFT on top of the UNO.                                             ///
  /// It's just below the ICSP, RX TX 5V GND. Connect it to the Wemos TX RX  ///
  /// 5V & GND with a cable.                                                 ///
  /// 5V -- 5V                                                               ///
  /// GND -- GND                                                             ///
  /// RX -- TX                                                               ///
  /// TX -- RX                                                               ///
  /// 19200 Bps was enough for me, but feel free to change the speed of the  ///
  /// Serial port. Remember to do it on the Wemos too !                      ///
  ///   20171116 Grumpf.                                                     ///
  // http://www.barth-dev.de/online/rgb565-color-picker/ here to choose your 16 bits colr !!!
#include <Adafruit_GFX.h> // Hardware-specific library
#include <MCUFRIEND_kbv.h>
#include <fonts/FreeSans9pt7b.h>
MCUFRIEND_kbv tft;
#define BLACK   0x0000
#define BLUE    0x001F
#define RED     0xF800
#define GREEN   0x07E0
#define CYAN    0x07FF
#define MAGENTA 0xF81F
#define YELLOW  0xFFE0
#define WHITE   0xFFFF
#define TRS80DarkGreen 0x0140
#define HayYellow 0xFFAA
#define Mud 0x59C5
#define Darkmud 0x4100
#define Blood 0x6000
#define Bone 0xeff9
#define Undersea 0x0085
#define Foam 0xa79f
#define Jungle 0x6544
#define Ivy 0x3921
#define Piggy 0xFBD7
#define Ham 0x88F4
#define Pumpkin 0xCCA0
#define ArduinoL 0x4D74
#define ArduinoD 0x2B2B
  ///     Parameters here are for 9341 Controller 320X240                    ///
int16_t ht, top, line, lines, scroll;
short FG, BG; // Foreground color, background
byte TexSiz, TexStyle = 1;
char Buff;
void setup()
  ///     INIT TFT, no test is made for the type of controller               ///
  ///               You may have to adapt the code to your controller        ///
  ///               Check with other examples and modify accordingly         ///
    tft.reset();
    uint16_t id = tft.readID();
    tft.begin(id);
    tft.setRotation(0);     //Portrait, scroll is only supported this way
    tft.fillScreen(BLACK);
    tft.setTextColor(HayYellow, Undersea);
    tft.setTextSize(2);
    tft.setCursor(100, 0);
    tft.print("ID = 0x");
    tft.println(id, HEX);
    top = 0;                      // these controllers scroll full screen
    FG = CYAN;
    BG = BLACK;
    TexSiz = 1;
    tft.setFont(&FreeSans9pt7b);
    TextSizechanged();
  ///     INIT SERIAL for input                                              ///
    Serial.begin(19200);
  ///                                   MAIN                                 ///
  /// It is assumed that the text does not exceed the number of characters   ///
  /// than can be printed in one line. If it is, then it'll appear on "top"  ///
  /// of the TFT.                                                            ///
  /// § character will reset the TFT to default type color and # will change ///
  /// The style to the next one. So if you wish your message to appear as    ///
  /// Style to, start it with $#, style 4 $### etc.                          ///
  /// For DOmoticz, %20 = Space, %23 = # and %24 =$
void loop()
    if(Serial.available()){
    cleartop();
    delay(100);
    tft.setCursor(0, 10 +(scroll + top) * ht);
    if (++scroll >= lines) scroll = 0;
    tft.vertScroll(0, 319, (scroll) * ht);
    while (Serial.available() >0) {
      Buff = Serial.read();
      if (Buff == '#') {
        TexStyle++;
        Buff = 0;
        Style();
      if (Buff == '$') {
        Buff = 0;
        TexStyle = 1;
        Style();
      tft.print(Buff);
    delay(100);
    line++;
void cleartop(){
  tft.fillRect(0, (scroll + top) * ht -1, 240, ht, BG);
void TextSizechanged()
  switch (TexSiz) {
    case 1: // Free Sans
      tft.setTextSize(1);
      ht = 10; //24 chars per line
      lines = 20;
	case 2: // 19 chars per line
      ht = 16;
      lines = 20;
    case 3: // 13 chars per line
      ht = 24;
      lines = 13;
    case 4: //  9 chars per line
      ht = 32;
      lines = 10;
  tft.setTextColor(FG, BG);
void Style(void){
    switch (TexStyle) {
    case 2 : // Doors & Windows closed
    FG = ArduinoL;
    BG = ArduinoD;
    case 3 : // Doors & Windows Opened
    BG = HayYellow;
    FG = Blood;
    case 4 : // Movement
    FG = RED;
    BG = Undersea;
    case 5 : // Lights
    FG = HayYellow;
    BG = BLACK;
    case 6 : //
    FG = Ivy;
    BG = Jungle;
    case 7 : //
    FG = Piggy;
    BG = Ham;
    default:
    FG = WHITE;
    BG = BLACK;
    TexStyle = 1;
tft.fillRect(0, (scroll + top -1) * ht -1, 240, ht, BG);  // Fonts do NOT draw background like raster so you need this...
That will allow me to have an Espeasy module for it. On the other hand; I handle other displays thanks to some CURL command. That will not be using Espeasy but would be a lot simpler.
Problem is, I have no clue how to do that. I tried some commands but it's too obscure for me.
Any advice ?
Re: Matrix Display with movement detector for custom message
#2 Post by Ath » 09 Feb 2021, 19:19
I have planned to do a MAX7219 dot matrix display plugin for ESPEasy (using a popular standard library), I just need to finish a few other projects first. Seeing this usecase just motivates me more to finish stuff and start this one asap :D
Grumpf
#3 Post by Grumpf » 09 Feb 2021, 19:28
Well in this case I guess I'll wait a bit and try to finish some other projects too.
Cheers !
Mariete
#4 Post by Mariete » 16 Feb 2021, 22:50
Ath wrote: 09 Feb 2021, 19:19 I have planned to do a MAX7219 dot matrix display plugin for ESPEasy (using a popular standard library), I just need to finish a few other projects first. Seeing this usecase just motivates me more to finish stuff and start this one asap :D
Very good news! I'll keep my eyes on this. Thank you! :-)
DIY CO2 monitor with ESP Easy at https://emariete.com/medidor-casero-co2/
ESP Easy related info at my blog: https://emariete.com/tag/espeasy/
GertSt
#5 Post by GertSt » 01 Oct 2021, 10:08
Mariete wrote: 16 Feb 2021, 22:50
Any news on this? I'm interested too ;)
#6 Post by Ath » 01 Oct 2021, 10:36
GertSt wrote: 01 Oct 2021, 10:08 Any news on this? I'm interested too ;)
I have created a PR in the ESPEasy repo on Github, #3688, and in the Issue that was created to get it in, there are a few test-builds available: #3422. (There's also a pdf of the documentation I wrote). I'd suggest to test using an ESP8266 with 4MB Flash like a Wemos D1 mini. It has enough GPIO pins available, after connecting the display, to accommodate f.e. a PIR sensor.
When connecting the display to 5V (with a proper power specification), then also use a level converter to protect the ESP ports as they only allow for 3.3V, and the 'high' signal is probably not enough to get the display going. The level converter will take care of that.
Users browsing this forum: Bing [Bot] and 34 guests
