switching relay with Temperature and/or Humidity
Beliar_666
#1 Post by Beliar_666 » 03 Feb 2021, 15:46
I want o switch a relay when my temp is under a certain value, and switch back when the value is reached back.
I Use a BME280 to measure and a relay connected to gpio12 I have figured out to switch the relay with following rule
On System#Boot do
 gpio,13,1
on Aussen#temperature do
  if %eventvalue1% > 27
          gpio,13,0
  if %eventvalue1% < 27
          gpio,13,1
Is this the right way? I tried it out and it works, but maybe i could do the ruleset better?
Re: switching relay with Temperature and/or Humidity
#2 Post by TD-er » 03 Feb 2021, 16:34
Nope that's not the right way.
The "on ... do" part of the rules mark a block of code that should be handled when there is an event.
So you cannot have an else part starting with on...do
If you try to match the same event for several values, it is best to check the %eventvalue1% values within this on...do .... endon block.
See also https://espeasy.readthedocs.io/en/lates ... Rules.html
Beliar_666
#3 Post by Beliar_666 » 03 Feb 2021, 18:27
ok, i tried the quick and dirty way, this also works:
On System#Boot do
 gpio,13,1
on Aussen#temperature>27 do
          gpio,13,0
on Aussen#temperature<27 do
          gpio,13,1
Is this the better way?
#4 Post by Ath » 03 Feb 2021, 19:58
You'd better, as suggested, have 1 event handler (on .. do/endon) like this:
On System#Boot do
  gpio,13,1
    gpio,13,0
    gpio,13,1
Beliar_666
#5 Post by Beliar_666 » 04 Feb 2021, 18:24
Ok, i tried it out and it works. I don´t understand it very well, but what exactly means %eventvalue1% and can i use %eventvalue1% in every rule or do i have to give it different numbers, e.g. %eventvalue1% , %eventvalue2% ... ?
#6 Post by Ath » 04 Feb 2021, 20:05
The up to date documentation on Rules can be found here: https://espeasy.readthedocs.io/en/lates ... Rules.html
Every event that's executed can get up to 4 arguments. These can be accessed by the %eventvalue1% through %eventvalue4% names. There is also %eventvalue%, and that's an alias for %eventvalue1%, often used when only 1 value is passed to the eventhandler.
The use of %eventvalue1..4% is advised over the use of [Task#Value], even if that should be the same value, as events are queued, including the values at that time, but other events, executed before the event at hand, can possibly alter the value, or a sensor may get new data, and that will get its own event queued after the current one.
