Hya,
for an application i'm building, i have a push button but want to trigger with long press only, to avoid and triggering by touching by mistake.
Is there a way to "disable" to short press?
Some samples for the following?
Long press event: If enabled the unit will detect a long press of a button. There’s three different behaviors of the long press:
Active only on low: this means that the unit will only be triggering the long press event if the signal is low. Two different event values are used, 10 if the state goes from 0 to 1 (Switch#State=10), and 11 if the state goes from 1 to 0 (Switch#State=11).
Active only on high: same as above but only triggered on high signal.
Active on high & low: the long press will be triggered both on high and low signals.
Thanks in advance!
Plugin 01 (Switch ) Push Button Longpress
Re: Plugin 01 (Switch ) Push Button Longpress
Simply don't assign any action to it.
I say that theorically, longpress or double never worked for me so far.
i was confused, as the docs are mostly not very friendly. Anyway, i spent about one hour testing, digging and found out the it works like a charm....
And doubleclick also works..
on PB#status do
if %eventvalue%=11 // pb#status 11 - long press and v1 = 0 -> turn ON
if %v1%=0
gpio,13,1
let,1,1
else // pb#status 11 - long press and v1 = 1 -> turn off
gpio,13,0
let,1,0
And as i'm a very lazy dog, i memorize almost nothing, i just learn, but don't memorize syntaxes, etc... i do it and save for later reference.
Glad you managed, I'll try again and share my experience with you if you don't mind.
Talk to you soon,
Talk to you soon,
