.esp dashboard reload on ios
supersjimmie
#1 Post by supersjimmie » 21 Dec 2020, 15:34
I tried the suggestions on:
https://www.letscontrolit.com/wiki/inde ... _Dashboard
and
viewtopic.php?t=7038
What I want to create is a simple page for setting my thermostat, which is a Level Control plugin via a mini dashboard, that also shows the current temperature which is updates every minute.
I do get either the Level Control setting from [thermostat#getLevel] working OR the current temperature updated via the json and the script.
<!DOCTYPE html>
<html>
<meta name="viewport" content="width=width=device-width, initial-scale=1">
<STYLE>
        font-family: sans-serif;
        font-size: 16pt;
    .button {
        margin: 4px;
        padding: 4px 16px;
        background-color: #07D;
        color: #FFF;
        text-decoration: none;
        border-radius: 4px
    table {
        border-collapse: collapse;
        width: 100%;
    th,
    td,
    h1 {
        text-align: center;
        padding: 8px;
</style>
<head>
    <script onload="setInterval()">
        var tempVarInterval = 1000;
        setInterval(async function () {
            response = await fetch("/json?view=sensorupdate");
            myJson = await response.json();
            tempVar = myJson.Sensors[12].TaskValues[0].Value;
            document.getElementById("tempId").innerHTML = tempVar;
        }, 1000);
    </script>
</head>
<body>
    <h1 style="color:Red; font-size:30px;">Temperatuur</h1>
    <div style="overflow-x:auto;">
        <table>
            <tr>
                <th>Huidige</th>
                <th id="tempId">t</th>
            </tr>
			<tr>
				<th>Thermostaat </th>
				<th>[thermostat#getLevel]</th>
			</tr>
			<tr>
				<th><a class='button link' href="thermostat.esp?cmd=event,tempup">Hoger</a></th>
			</tr>
			<tr>
				<th><a class='button link' href="thermostat.esp?cmd=event,tempdown">Lager</a></th>
			</tr>
        </table>
    </div>
</body>
</html>
When I call the file dashboardt.esp, the [thermostat#getLevel] piece displays the current state of the Level Control plugin. But the <script> piece does not work (so here it just says 't').
When I call the file dashboardt.htm, the script updates the id="tempId piece but the [thermostat#getLevel] simply shows "[thermostat#getLevel]" instead of becoming the current pluging setting.
To add: it does seem to work on my laptop with chrome and the file called thermostat.esp but not on my iPhone.
And yes, I want it on my iPhone since that is the most easy remote-control.
From what I understand, the [thermostat#getLevel] is only rendered if the page is ending with .esp.
And on my iPhone an .esp file does not run the script?
EDIT:
It does seem to come from this piece in the LoadFromFS.cpp:
  if (path.endsWith(F(".src"))) { path = path.substring(0, path.lastIndexOf(".")); }
  else if (path.endsWith(F(".htm")) || path.endsWith(F(".html")) || path.endsWith(F(".htm.gz")) || path.endsWith(F(".html.gz"))) { dataType = F("text/html"); }
  else if (path.endsWith(F(".css")) || path.endsWith(F(".css.gz"))) { dataType = F("text/css"); }
  else if (path.endsWith(F(".js")) || path.endsWith(F(".js.gz"))) { dataType = F("application/javascript"); }
  else if (path.endsWith(F(".png")) || path.endsWith(F(".png.gz"))) { dataType = F("image/png"); }
  else if (path.endsWith(F(".gif")) || path.endsWith(F(".gif.gz"))) { dataType = F("image/gif"); }
  else if (path.endsWith(F(".jpg")) || path.endsWith(F(".jpg.gz"))) { dataType = F("image/jpeg"); }
  else if (path.endsWith(F(".ico"))) { dataType = F("image/x-icon"); }
  else if (path.endsWith(F(".svg"))) { dataType = F("image/svg+xml"); }
  else if (path.endsWith(F(".json"))) { dataType = F("application/json"); }
  else if (path.endsWith(F(".txt")) ||
           path.endsWith(F(".dat"))) { dataType = F("application/octet-stream"); }
#ifdef WEBSERVER_CUSTOM
  else if (path.endsWith(F(".esp"))) { return handle_custom(path); }
#endif
This tells to only handle .esp files as custom files in such a way that the [themostat#getLevel] is rendered.
However, I think I should not just modify this to also handle .htm / .html files in that same way...
Would it be wise to add something to the top of this list that makes a path that endsWith "mycustom.htm" also a custom file?
(and then call my file mycustom.htm)
Re: .esp dashboard reload on ios
#2 Post by Ath » 21 Dec 2020, 15:58
supersjimmie wrote: 21 Dec 2020, 15:34 To add: it does seem to work on my laptop with chrome and the file called thermostat.esp but not on my iPhone.
Have you considered installing Chrome on your iPhone to try and see if that works as intended?
supersjimmie
#3 Post by supersjimmie » 21 Dec 2020, 16:16
Actually yes and no.
I would like this to work, out of the iphone-box.
We have a couple of iphones here and all keep using the default Safari just as usual.
In the meantime, I tried my own suggestion.
The mycustom.htm is now filled with the #getLevel piece as expected (20.30) but the current temperature is still 't' instead of e.g. 20.23.
So I guess this is not really tied to the file being called *.htm but something else that breaks between espeasy, the script and the browser on the iphones.
EDIT:
On my own phone I installed chome, but no result.
The first value remains 't'. (while it works still on Chrome on my Windows laptop)
chromo23
#4 Post by chromo23 » 12 Oct 2021, 16:09
since i had the same problem for a while i decided to make my dashboard better.
I figured out, that you have to use a html in order to work.
Here my example. called it dashboard.html
Bildschirmfoto 2021-10-12 um 15.49.08.png (31.28 KiB) Viewed 4459 times
<!DOCTYPE html>
<html>
<link rel="stylesheet" href="esp.css">
<STYLE>
        font-size: 12pt;
        background-color: #2b2a2a;
        color: #fff
    .button {
        margin: 4px;
        padding: 14px 60px;
        color: #FFF;
        border-radius: 14px
</STYLE>
<head>
            response = await fetch("json?view=sensorupdate");
            tempSoll = myJson.Sensors[5].TaskValues[0].Value;
            document.getElementById("tempSollId").innerHTML = tempSoll;
            tempVar = myJson.Sensors[7].TaskValues[0].Value;
            document.getElementById("tempVarId").innerHTML = tempVar;
            humVar = myJson.Sensors[7].TaskValues[1].Value;
            document.getElementById("humVarId").innerHTML = humVar;
        }, 1000);
    </script>
</head>
<body>
        <br><br>
        <br><br>
        <center>
            <table>
                <tr>
                    <td style=font-size:30px;"> Soll:</td>
                    <td style=font-size:30px;" id="tempSollId">Tsoll</td>
                    <td style=font-size:30px;">&#8451;</td>
                </tr>
            </table>
        </center>
        <br><br>
        <center>
            <table>
                <tr>
                    <td style="text-align:right;"><a class='button' onclick="submitdown()">-</a>
                    <td style="text-align:left;"><a class='button' onclick="submitup()">+</a>
                </tr>
                <br><br>
            </table>
        </center>
        <br><br>
        <br><br>
        <center>
            <table>
                <tr>
                    <td> Temperature:</td>
                    <td id="tempVarId">Temp</td>
                    <td>&#8451;</td>
                </tr>
                <tr>
                    <td> Humidity:</td>
                    <td style="text-align:right;" id="humVarId">Hum</td>
                    <td>%</td>
                </tr>
            </table>
        </center>
        <br><br>
        <center>
            <table>
                <tr>
                    <img src="Lamp[dummy#boost].svg" width="70" height="70" alt>
                    <br><br>
                    <br><br>
                    <td><a class='button' onclick="submitboost()">Boost</a>
                </tr>
            </table>
        </center>
        <br><br>
        <script type="text/javascript">
            function submitdown() {
                var xhr = new XMLHttpRequest();
                xhr.onreadystatechange = function () {
                    if (xhr.readyState === 4) {
                xhr.open('get', 'dashboard.esp?cmd=event,down', true);
                xhr.setRequestHeader('Content-Type', 'application/x-www-form-urlencoded; charset=UTF-8');
                xhr.send();
        </script>
            function submitup() {
                xhr.open('get', 'dashboard.esp?cmd=event,up', true);
                xhr.send();
        </script>
        </script>
            function submitboost() {
                xhr.open('get', 'dashboard.esp?cmd=event,boost', true);
                xhr.send();
    </div >
I did this mostly with copy´n´paste because I've never really dealt with it. I guest it can be done nicer code wise but it works except the part with loading the svg. But this will be a story for another thread.
