Co2 Sensor Telaire Т6703
please help add Co2 Sensor Telaire Т6703
Re: Co2 Sensor Telaire Т6703
I made an issue for it on GitHub. https://github.com/letscontrolit/ESPEasy/issues/3397
Requests like these can best be done on GitHub as they tend to get lost here on the forum.
I never saw those sensors before.
Apparently they can be connected via UART and I2C, which makes them quite versatile.
This from the datasheet about the ABC also looks quite OK:
That's a lot more useful compared to the Winsen MH-Z19.With ABC Logic enabled, the sensor will typically reach its operational accuracy after 24 hours of continuous operation.
Sensor will maintain accuracy specifications with ABC Logic enabled, given that it is at least four times in 21 days exposed to a reference level of 400 ppm.
Wow, that's an ancient sensor
Users browsing this forum: Ahrefs [Bot] and 46 guests
