what is preferred way (if exists) to read state of output GPIO within rules and GPIO is not defined within Taks/Devices? Is there a way to make such
I have relays on GPIO 15 and GPIO4 and i want to make following if clause (below example doesn't work):
if [GPIO#15]=1 and [GPIO#4]=1
GPIO,15,0
GPIO,4,0
Reading (output) GPIO state within rules
Re: Reading (output) GPIO state within rules
See the "monitor" command: https://espeasy.readthedocs.io/en/lates ... ore-events
N.B. this does require a recent build.
I use Monitor function on input GPIOs in order to get event when state is changed (button pressed).
I am asking for solution to get state of output GPIO which is used for controlling relay. Since I dont want to get events when changed I am asking for solution like in example in documentation
but for this I have to define every output as task/device.
Is Monitor command also useful for monitoring output GPIOs without using events which are generated on change? How many system resources does Monitor command consume?
if YES I assume that after enabling Monitor on output GPIO (eg. GPIO15) I will be able to
if [GPIO#15]=1
// do something
if [Plugin#GPIO#Pinstate#13]=0
// do something
if [GPIO#15]=1
// do something
I´m only beginner at this topic but according my understanding the monitoring function is always enabled for Gpios.
I use the monitor function for additional GPIOs of a PCF8574 IO-Extender and here you have to enable it by rule. But not for GPIOs and therefore your last example can be used directly.
Best regards
P.S.: If I´m wrong regarding enabled monitoring for GPIOs... I use it for 6pcs PCF8574 IOs and have not recognized any load or memory impact.
Only as example how I use it. I like to get an update by Mqtt after reboot about the status of the output and an update in case of a change.
I haven´t had enough free devices to do this by internal input/switch.
Best regards
on System#Boot do
Monitor,pcf,1
Monitor,pcf,2
Monitor,pcf,4
Monitor,pcf,5
Monitor,pcf,7
Monitor,pcf,8
pcfgpio,1,1
pcfgpio,2,0
pcfgpio,4,0
pcfgpio,5,1
pcfgpio,7,1
pcfgpio,8,0
on MQTT#Connected do
Publish,%sysname%/PCFGPIO/P1Gruen,[plugin#pcfgpio#pinstate#1]
Publish,%sysname%/PCFGPIO/P2Rot,[plugin#pcfgpio#pinstate#2]
Publish,%sysname%/PCFGPIO/P4BlauET1,[plugin#pcfgpio#pinstate#4]
Publish,%sysname%/PCFGPIO/P5BlauET2,[plugin#pcfgpio#pinstate#5]
Publish,%sysname%/PCFGPIO/P7GelbAT1,[plugin#pcfgpio#pinstate#7]
Publish,%sysname%/PCFGPIO/P8GelbAGarten,[plugin#pcfgpio#pinstate#8]
on pcf#1 do
on pcf#2 do
on pcf#4 do
on pcf#5 do
on pcf#7 do
on pcf#8 do
Yes, monitor command operates also on output pins.I am asking for solution to get state of output GPIO which is used for controlling relay. Since I dont want to get events when changed I am asking for solution like in example in documentation
